New member questions
Just purchased a black 2002 Explorer XLT. I have the ever popular door ajar light stays on problem which I think I can fix, thanks to this forum! And sometimes the back-up warning works and then doesn't?
When the truck is running I hear a low clicking sound coming from the rear driver side under the interior cover. Fuel pump noise? There is a wire with a connector dangling in the glove box. Light connection? No light housing. What do you guys use on the plastic body panels and bumpers to restore them? Great forum! Thanks all! JP
Key description is "BLACK", had you bought any other colour you would not have had these issues....
How many terminal locations are in the connector dangling in the glove box, and how many of those terminal locations are populated with wires? Is the connector body black, gray, or off-white? It could be the trailer wiring connector which is normally taped up behind the glove box.
By plastic body panels are you referring to body colored panels or flat black panels? Are you just trying to remove scratches and oxidation from them? If body color and you're just trying to get them to shine, you can use the same products on them that you would use on the painted metal panels.
-Rod
-Rod
Thanks for your help! Door Ajar is now door closed and no other weird alarm or dingys going on!
-Rod
It was the switch on driver's side. When I removed it there was resistance when pushing the pin in. So I guess the whole switch was shot. Thanks for your help!
