Growling noise when turning right
Okay so i have this growling/crunching/poping noise from the driver side wheel area when i make a right turn. It gets much worse after i have been driving the truck on the highway. Going straight is fine and turning left is fine. I took the hub off and it seemed fine. While i had everything apart i pulled the stub shaft to replace both the seals because they looked pretty bad. Put everything back together with the original hub and the sound went away for about 2 days. After it came back i took it apart again and replaced the hub. The noise is still there. Any ideas? I wouldnt think that the new seals made anything change for this kind of noise... maybe coincidence? Somewhere in the suspension maybe? I read one post somewhere about the plastic things between the leaf springs or something like that causing his truck to make some wierd noises while turning... so i looked at mine and they are definatly broke/wore but im not sure if that is even worth the time taking apart just for it to not be it. Maybe ill stick a screwdriver between it and take it for a spin to see if it makes a difference before i take it apart. At this point im lost... suggestions please.
Thank you
**addition**
I took it through a rut going slow and when the front end droped into the rut going straight it made the same noises... donno if this matters but possibly in suspension like i was thinking?
Thank you
**addition**
resq302
08-21-2018 10:29 AM
Fordbronco69
12-13-2012 07:54 PM
