What did you do to the X today?
Installed the caliper hanger with the new backplates. I had put the castings in rust-x and then painted them with high temp paint. Even though the plates came painted, I hit them with another coat of high temp paint.
Pressed out the bearing races in the hubs, degreased and cleaned the hubs, and pressed in the new races and put in the new inner bearing, new oil slinger and a Timken inner seal. Hubs are ready to install. Thank God for my Harbor freight 20 ton press and the air over hydraulic jack I put on it. Made life sooo much nicer than the old days banging races in and out with a bronze drift!
Tomorrow is time to assemble parking brakes, and put the hubs and axles on. Then the new brackets, calipers, pads, rotors, and hoses. Then bleed it.it and replace all the cables. Probably two days more. I'm slow as hell anymore.
Then on to the front axle!
I'm a little pressed for time as we leave for a Southern trip on the 28th and only have next Wed & Thurs to finish up the EX and TT jobs. Besides a ton of yard and garden work I managed to replace the 3 rear axle brake hoses with the Russell ones, had the rotors cut, cleaned and lubed the slide pins, installed new Hawk LTS pads and installed a set of speed bleeders Tuesday and last night after work. I would have liked to get a coat of paint on them but there just isn't time, maybe during the Summer.... I'm hoping to get the rear bled and then get at least one front done tonight and finish up Friday before the rain starts. Then I just have to do an oil and filter change, lube the Ex and TT and wax about an acre of panels between the two. I'll be good and ready for vacation by then!
So I was washing the EX the other day and decided to power wash underneath. I found that the hangers behind the muffler have rusted through and there are large holes in the pipe. I bought a pre-bent 45* and hopefully will get it spliced in today.
I think its been this way for a while, I noticed the soot inside the tailpipe was being cleaned off. I guess water was getting in there and blasting it off jet style.
I have the MBRP 4" and will be replacing it with a Banks w/Power elbow. Im going to eventually have the turbo off to change the impeller and intake housing so I'll do it then. Always had good luck with the Banks stuff.
I removed the front sway bar last night. Can't keep bushings in the right side for some reason. EX rides nice without it though so I'm going to keep it off for the time being. Also installed an Aero 4040XL muffler in place of the straight pipe. Really liking the quite and I'm sure the wife will too. Trying to kill some drone when pulling the TT. Fingers crossed it works.
with your lift, do you have extended length links? or did you flip the frame mount to under the frame rail? see picture below for what I'm talking about. It's possible you have too much static stress on the sway bar and that's causing the issue.
normally that frame mount is located inside the frame rail. with about 4" of lift on one of my X's I had to flip that mount to get proper sway bar alignment
where are the end links on the frame mounted?
Install, wash hands, order.....
Glad to see you are healed up enough to spin the wrenches again Bion!
Maintenance, Maintenance, Maintenance.
"Car and home ownership means having something to do every weekend for the rest of your life" - My Dad.
