What did you do to the X today?
Im a very patient man (read "lazy"), the 6.0 cooler has only been sitting in the garage for about two years, but I'm going to "fast track" it's installation while I do the AC condenser. My F-650 dash has been gathering dust for over four years waiting for its mods, paint and installation and my 4.88 front axle has been waiting for almost seven years I think.
Ac compressor leaking, no problem just add more oil. This came out of accumulator only, haven't pulled compressor yet.......
between the accumulator and the compressor i got out about 25oz, give or take probably 1oz from what i spilled. seriously, who just floods the system with oil rather than fixing the leak????? no idea how much i will put back in now :/
well new compressor, orifice, and accumulator installed. 5oz in compressor and 3 in accumulator is all the oil I had. i drained out 5oz of oil from new compressor, maybe i shouldn't have drained it. tomorrow it goes to the shop for the vacuum/charge
it has like 35ft of wire included. all power and signal wires are done up front by the head unit, then i fished the wire up and across the headliner, through the wire loom in the top of the hatch, around the hatch and out the left hand side of the handle. only thing i had to drill was the mounting screws. pretty dang nice picture too with my several year old Pioneer deck, but the deck connection is universal just a single RCA so use it with whatever
Have your shop add more leak dye while you're in there.
Over the last two days:
Changed oil, Replaced my leaking 6.0 trans cooler (ouch that hurt my wallet), Flushed the OTW cooler with Kooler Kleen, rebuilt the bypass tube valve, replaced the Transmission lines, finally put in my Factory Tech accumulator body Ive had since forever, cleaned the pan, full trans fluid change, changed the axle fluids and put on some new covers (Ford aluminum for the rear and a SOLID brand for the Dana 50)that I've had for years and never put on, removed the CURT front hitch (I don't need it anymore since the bumper has one), repaired some light rust found after I removed the lights and grill, combed and cleaned the radiator and condenser, replaced the grill and emblem with all new. Drained, flushed radiator and coolant systems and replaced with new Valvoline G-05.
Now to take it out for a test drive of the new accumulator body. Then hook up the trailer and see what the throttle body does for towing.
I just hit 100k miles two weeks ago.
edit: I forgot to state that I replaced the upper and lower radiator hoses, the overflow tank hose, and all heater hoses.
i think he usually puts in dye anyway, but will double check.
