What did you do to the X today?
Old 07-25-2016, 05:11 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Originally Posted by 7.3Excursion4x4
Turned 380,000 miles.
Wow!
In your honor from CA.
  #42887
Old 07-25-2016, 10:00 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,109 Likes on 560 Posts
What all have you had to replace to get that far? Looks like all the engine peripherals based on your sig. Transmission?
Congrats, that's a long way!
  #42888
Old 07-25-2016, 11:51 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Originally Posted by carbon coupe
If you put too much grease in, it could be spitting out through the rear seal of the hub. After about 100 miles, look inside the rotor, if theres a ton of grease, or any for that matter, its coming out the seal.
About 15 pumps of grease was inserted, I believe Tom (WE3ZS) used as much as 22. Noise was there before, during and after. I have seen what you are referring to before though.
  #42889
Old 07-26-2016, 07:29 AM
7.3Excursion4x4's Avatar
7.3Excursion4x4
7.3Excursion4x4 is offline
Only things I've replaced out of necessity was the tranny at 361,000 (Yes, that was the factory one), injector cups, brakes, rotors, fluids, water pump, alternator (6 or 7) and serviceable parts like ball joints and u-joints. Go fast parts changed because I wanted too, not out of necessity.
I've run full synthetic AmsOil since I've owned it at 70,000 miles.
I have OCD when it comes to maintenance. I have a detailed spreadsheet for every dime I've spent on it. If I replace a dome light, or add fuel, or anything else, I document the date, mileage, description, cost, and where purchased. Good way t o keep track of whats going on with it.
  #42890
Old 07-26-2016, 03:03 PM
FLO98's Avatar
FLO98
FLO98 is offline
After days of working on it, new stand pipes, new nipple cups, resealed injectors, new adrenaline pump. I'm getting a no start and only building about 75 psi. Plenty of cranking time (over 10 minutes total with FICM relay removed) still no start. Called a friend's shop and it'll be getting a piggy back ride over there to get checked out. My wife and kids need my attention much more than I need to forms another day under the hood of this blasted thing. Love the truck but dangit this is getting old.
  #42891
Old 07-26-2016, 04:27 PM
NorthwesternCowboy's Avatar
NorthwesternCowboy
NorthwesternCowboy is offline
05-07 Conversion Grill installed. Props to Sinister Diesel. Grill went in in less than 3 minutes (not properly captured in my Before/After pictures) and looks awesome.
Next up: Clear 05+ headlights and cab lights. (recommendations welcome)
  #42892
Old 07-26-2016, 06:40 PM
FLO98's Avatar
FLO98
FLO98 is offline
And off she goes!!!
  #42893
Old 07-26-2016, 08:00 PM
hwybee22's Avatar
hwybee22
hwybee22 is offline
Originally Posted by FLO98
And off she goes!!!
Where is she going?
  #42894
Old 07-26-2016, 08:14 PM
Daewoo's Avatar
Daewoo
Daewoo is offline
Picked up a set of "T codes" to hopefully get the bumpstops off the axle.
  #42895
Old 07-26-2016, 09:49 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Those look stout!
  #42896
Old 07-26-2016, 10:12 PM
Peace2Peep's Avatar
Peace2Peep
Peace2Peep is offline
Dropped my poor sad baby off at Full Force Diesel in Mufreesboro, TN (Yup, 10 hours from home) for a major stalling issue(they think its either FICM, FICM Harness, or Engine Harness). I also need injectors (200K on the factory ones) and the charge cooler tubes/boots are leaking...and a slew of minor grievances. I figure I'd rather do a "little" road trip for the best injectors from Cass and his teams install rather than give up $1200 in core charges and use my not so elegant local shops. I'm also considering a little bump in power...155's and a powermax anyone? I'm more than a little stoked!
  #42897
Old 07-26-2016, 11:13 PM
FLO98's Avatar
FLO98
FLO98 is offline
Originally Posted by hwybee22
Where is she going?
Hopefully to get her running again. A local shop run by neighbors and friends in Northeast Ohio, luckily only a 6 mile tow. Just didn't have time, energy, or diagnostic capability of my own. First ever piggy back since I've owned it.
  #42898
Old 07-27-2016, 02:37 AM
william_04_x's Avatar
william_04_x
william_04_x is offline
Now you're talkin. Cass is the man. Tear it up!! P2P
  #42899
Old 07-27-2016, 04:00 AM
hwybee22's Avatar
hwybee22
hwybee22 is offline
Please keep us updated. Only 155s?
  #42900
Old 07-27-2016, 04:57 AM
Jointasset's Avatar
Jointasset
Jointasset is offline
Take a tour of Barrett if you have time when you go back to get your X. It's not quite as expensive a hobby as the X is......up front at least.
Quick Reply: What did you do to the X today?
