What did you do to the X today?
Maybe you are just referring to diesels but my early 2001 is not digital.
I didn't lay in any sound deadening... I may down the road (wish I had thought about it for today but alas I didn't).
Installing the new carpet seriously sucked! The carpet came molded but not cut and the big girl needs lots of holes in the carpet. The carpet itself wasn't hard to cut just tedious. The pad on the other hand was terrible! It's a real dense pad that is very fibrous so the razor knife and heavy scissors were both mostly ineffective but they eventually got it done.
As much as I hated the install process I do love the Finished product. That said... Taking pics of black carpet is pretty futile but here you go:
Front
Middle seat
I did the way back too but that was a few days ago. I have ordered the matching floor mats to match the carpet.
Front
Middle seat
have you considered all-weather mats, specifically the digital cut ones that fit snug and cover way more carpet than the stock mats do? i've had weathertech, didn't care for them in my f350 personally, so i just ordered a set of Husky WeatherBeater mats for my dually, if i like them i may get them for the excursion also (haven't even looked if they offer them for it though)
black paint just sucks. i didn't want my f350 black but i couldn't pass up everything else about it ... one day maybe i'll paint it silver like i want lol
i like that sport trac. that's your...grandfathers IIRC? from the part showing in the pic it reminds me of my parents old 2001 f150 CC harley (2nd year they made them i think) we had back then. loved that truck, and back in 2001 if you had rims, let alone 20" rims, you were the ISH! those days are all gone now....lol
Amen the the annoying creaking, I have new Center Link waiting to be installed, but until I get around to it.... It's getting embarrassing.
Parts list:
<img src="http://i1175.photobucket.com/albums/r624/weeves/hid-invoice_zpsmnfbbdis.jpg">
OCI Glue = Butyl tape. 2000-2004 EX requires the 9007 connector adapter while the 2005 requires the H13 connector.
Separate the lens from the headlight housing. You can either use a heat gun or stick them in the oven at 200*F for 10 minutes and then pry the two halves apart. Butyl tape sticks to everything and difficult to clean off. I found that isopropyl alcohol did the best job removing it.
<img src="http://i1175.photobucket.com/albums/r624/weeves/hid1_zpsxhizvazt.jpg" height="540" width="720">
Remove the reflectors. The one for the turn signal is bolted on with 3 phillips screws and the one for the headlight is clipped on. Be careful not to break reflector mounts the when prying/pulling the black clips.
<img src="http://i1175.photobucket.com/albums/r624/weeves/hid2_zps7zvlbpma.jpg" height="540" width="720">
Remove this piece:
<img src="http://i1175.photobucket.com/albums/r624/weeves/hid3_zpsc5wa8buo.jpg" height="540" width="720">
Grind down the base of the reflector flat so the threaded shaft on the projector sticks out as much as possible. I used an angle grinder but a palm sander would have been ideal. Also, enlarge the opening with a dremel so the shaft fits through.
<img src="http://i1175.photobucket.com/albums/r624/weeves/hid5_zpsnmc1tlet.jpg" height="540" width="720">
Drill a hole/opening for the high beam wires.
<img src="http://i1175.photobucket.com/albums/r624/weeves/hid7_zpsffpsdgrf.jpg" height="540" width="720">
Install projector, mounting washer, nut (hand tight), HID bulb, and bulb cap/nut (hand tight).
Install relay and ballasts. Install adapter connector to the 3 wires with connector pins on the relay. Connect it to either the right or left headlight harness on your Excursion. I chose to install it on the right (passenger's side). WHITE = Low Beam; Blue = High Beam; Brown = Ground
For 2000 Model Year:
Passenger's Side - Dark Green/Orange Stripe = Low Beam; Light Green/Black Stripe = High Beam; Black = Ground
Driver's Side - Dark Blue/White Stripe = Low Beam; Light Green/Black Stripe = High Beam; Black = Ground
<img src="http://i1175.photobucket.com/albums/r624/weeves/hid8_zpsekqrfpra.jpg" height="540" width="720">
Install reflector/projector assembly to headlight housing and bolt it up to your truck. Connect the wiring and turn on the headlights. Rotate the projector until the cutoff is horizontal. Then torque down mounting nut to the reflector housing while holding the projector.
Repeat for other side. Measure the distance between both of the projectors, back up 25 ft and measure the distance of the "steps" of the cutoff on the wall. Make sure those measurements are equal.
Install the turn signal reflectors and then apply the butyl tape around the headlight. Install the headlight cover, put the headlights in the oven for 10 minutes, and then squeeze the two halves together.
There were no instructions/diagrams included with this kit but I found these links to be helpful:
TRS Tips: Retrofitting the Morimoto Mini H1 6.0 into 9006, 9007, H11, H13 Headlights - YouTube
TRS Tips: How to Adjust Headlights for the Perfect Aim! - YouTube
https://www.ddmtuning.com/support/in...in-assignments
Remove this piece:
AWESOME THANK YOU! The parts list was definitely helpful, you did a thorough job. Now I need to order this stuff and get started on mine.
It was a scorcher. I'm not ready for the summer heat.
