Power Seat Won't move back
Old Oct 12, 2018 | 05:44 PM
  #61
PrescottIce's Avatar
PrescottIce
Originally Posted by 01__Excursion
Here is a diagram for 2001, I don't recall memory seat being avail till 2002 and beyond, I could be wrong of course.
But on my 2001 power seat system, it's very mechanical, and analog. No end of travel switches, or photo electric wheels, just cut and dry, and appears to use just the thermal overloads.
Although not listed as to what the max load amps are, it's possible that your motors, and or tracks are creating enough drag/resistance to trip the thermal overload on any of the motors, this may coincide with your intermittent operation, there appears to be one for each motor. You can certainly use an amp probe on the main voltage wire to the switch set, or each motor voltage wire to get a current reference, then compare to what others, or myself measure for current draw.
Thanks for the diagram. I actually wish mine had been that simple. Memory seats are nice until you have to diagnose an issue.
I thought about a thermal protected motor, which I why I asked about coming back later and being able to move it further in the same direction. If that's a no-dice, I'd guess it isn't thermal... I'm now even more a fan of putting power to the offending motor itself and seeing what goes down.
Old Jan 10, 2019 | 12:16 PM
  #62
Shamara Colley's Avatar
Shamara Colley
My 2012 Ford F150 Driver Seta Won't Go Back
I'm in need of help... our was deployed and his truck has been at the house. We used it to pick another vehicle up form the shop and now the seat won't go move back. It goes up/down/forward... but not back. He's coming home in less than a week and I'm in a jam. I did try to recline it back as suggested but that didn't work. Although I wasn't sitting in the seat (will try that this evening). Any other suggestions? Please help.
Old Dec 31, 2019 | 02:50 PM
  #63
Randal Barrick's Avatar
Randal Barrick
2004 F250 seat stuck forward
First post here: Thanks to everyone for all the advice.
My issue was the seat got stuck forward and wouldn't move back. All the other motors worked, including the up and down on the center switch. After checking the fuse, which I didn't expect to be blown given all the other motors worked, tried the seat back trick but no luck. Then tried the seat back trick again and again (frustration) and then tried the switch again. This time tried the switch, which previously just went "clunk" a bunch of times and it moved just a little bit. Then it started to move back. Guessing the forward position must have untracked the motor somehow and it finally got back in position to move the seat.
Now I just have to figure out how to keep my wife from messing with the seat.
Old Dec 31, 2019 | 04:41 PM
  #64
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You could become a very rich man if you can figure that one out.
Old Dec 19, 2020 | 09:47 PM
  #65
Fountaingirl's Avatar
Fountaingirl
Drivers seat not moving
Originally Posted by Skullonarm
Every now and again my driver side power seat will not move either. This is what I found. After spending half an hour checking fuses,wires,motors and what not I said hey dipstick, see what the owners manual says about power seats. Sure enough deep within the seat section, it states that if the power seat doesnt't work, put the seat back section of the seat down to it's lowest position a couple of times. This somehow resets the body module for the driver seat. Weird but it has worked several times for me. I just have to remember to do this, before I go into full on trouble shooting mode again.
My 2008 Expedition Limited EL's driver seat would not move forward or back, just clicked. But all other functions worked. Tried the reclining trick and it worked!! Love this forum.
Old Dec 25, 2020 | 06:56 AM
  #66
afinepoint's Avatar
afinepoint
Didn't work for me. I remember removing the seat and cleaning the switch contacts. That fixed it. Though it isn't 100%. Fortunately I put < 200 miles a year on the truck so if it acts up I only have to endure it for a day or so.
Old Mar 17, 2021 | 11:42 AM
  #67
Tommy Duckworth's Avatar
Tommy Duckworth
Seat swap.
HELP! I just purchased a set of 40-20-40 front seats from a 2009 super duty. I plan on putting them in a 2004 Ford F-450 XL. The work truck F-450 is an XL so I know I have no power. No big deal I can run power to the seats. They will be a no brainer on the actual swap from the bench to split bench. My question is before I do this...... I have tested the seats by direct connection to a battery. The driver has the 4 wire and I know grey-red is hot and black-violet is ground. Same for both driver and passenger except driver also has seat belt chimer also wired in the connector. When I direct connect the grey-red to power and black-violet to ground everything works except one of the seat directions. Both the front and rear up-down work, but forward only works. If I reverse wires to flip hot and ground, everything still works but the opposite direction of reverse works on seat positions, and no forward. I'm at my wits end! What am I missing. I see no memory controller and this is the same for both driver and passenger. Please, before anyone asks, I have searched the forums for over 2 hours.
Old Aug 15, 2022 | 01:30 PM
  #68
Brian2j's Avatar
Brian2j
2nd Gear
Where is lever located
^ yeah it's in there. The funny thing is, after I read that I said yea right! how are you supposed to move the power seat if it's not working (duh). Then I realized that there is a lever that performs this function. Somewhere in the automotive world of engineers, there's at least one guy, who probably still gets a kick out of this.
im in the same boat, where is lever to recline seat located? Mine is stuck but memory heater and cold seat work
Old Aug 15, 2022 | 02:03 PM
  #69
Brian2j's Avatar
Brian2j
2nd Gear
Old Sep 17, 2024 | 01:16 PM
  #70
RandomTruckOwner's Avatar
RandomTruckOwner
2nd Gear
https://www.ford-trucks.com/forums/9...move-back.html
Old Sep 17, 2024 | 01:24 PM
  #71
RandomTruckOwner
2nd Gear
I come from the future—spoiler: it's still not great, but at least my power seats work. 😅 I had to give this a go a few times, and eventually, it did the trick. Picture me, in full recliner wrestling mode, holding up the reclining lever while channeling my inner mechanic with one hand on the switch. After a few tries, victory was mine! At first, I thought you were trolling with this secret seat reset sorcery, but as the kids say these days, “no cap.” Appreciate you sharing this magic!
Old Sep 17, 2024 | 03:20 PM
  #72
John in OkieLand's Avatar
John in OkieLand
it only took $500 for the Ford dealer to fix my sister's 2010 Raptor's passenger seat.
the back leaned down to the floor, and would not return.
the module that controls it was bad.
my '02 Excursion driver seat is a mess, it won't move unless I am out of the seat.
Country_Mouse
Jun 18, 2016 01:30 PM
rowekmr
Jan 5, 2014 05:00 AM
ScubaCat
2004 - 2008 F150
Feb 19, 2012 11:02 AM
