Power Seat issues/questions
Old Mar 31, 2013 | 01:01 AM
rowekmr's Avatar
rowekmr
Hello
Just picked up my 2nd Ex this one being a 03 6.0L and the driver's power seat doesn't work neither does the power pedals. This wouldn't normally be a problem since I am the only one driving it but the seat is all the way forward and I am 6'4". The passenger seat works and the driver's heated seat button work but neither buttom or **** for movement. I don't have the owners manual and wanted to find out which fuse should I check. Could it be the motor or something else? What other Ford model seats are a direct bolt it with no modifications (SD?)
Old Mar 31, 2013 | 01:31 AM
Stewart_H's Avatar
Stewart_H
At least up through 2012 SuperDuty, according to this thread: https://www.ford-trucks.com/forums/1...l#post11778350
Stewart
Old Mar 31, 2013 | 10:41 AM
greentree ford's Avatar
greentree ford
also check for loose connection under drivers seat, could also be the switch
Old Apr 4, 2013 | 03:53 PM
rowekmr's Avatar
rowekmr
The dealership says it need a seat module which they quote $500 installed. Now I am contemplating just getting another take out seat.
Old Apr 4, 2013 | 04:35 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I dont recall which fuse it is, but its one of these type, also this color I believe (30A)
Old Apr 4, 2013 | 06:04 PM
phnguyk's Avatar
phnguyk
I also need a new seat module, I remember reading somewhere, maybe here that whether new, used or whole new seat with it, they need to be programmed by the dealer. Now I don't remember if that is just because our EX has memory seat positioning or not. For giggles try reclining the seat back all the way back for a few seconds and then try moving the seat. Read it, tried it, worked, sometimes it does, other times I have to pull all the plugs under the seat for a while.
Ignore if you've found a blown fuse.
Old Apr 4, 2013 | 09:52 PM
baller9409's Avatar
baller9409
mine used to freeze up all the time. I unplugged the seat belt chime under the seat and it hasn't broken since
Old Apr 5, 2013 | 12:49 PM
B846B's Avatar
B846B
Did the dealer already look into the module or did they just give you a quote over the phone?
Try disconnecting all the wires to the module, it is a little tight down there. If you can't, remove the seat and then do so. After a few minutes reconnect and see if it resets.
I had a similar issue three weeks ago. Research indicated the power seat module, which a new one needs to be reprogrammed by Ford. I ended up buying a new module from Tousley Ford and went to my dealership to have it installed/reprogrammed. The dealership advised that my module was fine once they reconnected everything. I haven't had any issue since.
So in an effort to save you money try this first.
Old Apr 5, 2013 | 02:55 PM
Skip1970's Avatar
Skip1970
What year started menory seats?
Old Apr 5, 2013 | 09:22 PM
phnguyk's Avatar
phnguyk
Our's is '04 EB. Not sure what year they started to offer.
Old Apr 6, 2013 | 02:04 AM
beachcomer1962's Avatar
beachcomer1962
mine were acting up and I unplugged the switches under drivers seat and it fixed it.Its free and worth checking...hope this helps
Old Apr 6, 2013 | 02:43 AM
cameeks's Avatar
cameeks
My 02 limited has power memory seat. Only problem I have is it is slow going forward. Sometimes sticks.
Old Jan 5, 2014 | 05:00 AM
rowekmr's Avatar
rowekmr
Sorry for the late response but the truck was in the shop for months dealing with engine issues and when it came out I had a credit with Ford so I had them repair the seat. I haven't read the receipt but I am almost sure it was the module. The first time the seat work but no memory or heat and after I took it back complaining of no heat they replaced it again (said the previous module was wrong one) now all works fine. Thanks for all the assistance.
LeeroyDiesel
Sep 17, 2024 03:20 PM
Country_Mouse
Jun 18, 2016 01:30 PM
Jmatthews
Electrical Systems/Wiring
Mar 30, 2009 07:24 AM
79REK
2004 - 2008 F150
Sep 11, 2004 04:50 PM
