T-18, problems going into gears
Old Aug 7, 2010 | 04:00 PM
FordF-250_460's Avatar
FordF-250_460
so I just bought a 1990 F-150 with the borg warner T-18. I was told by the seller that it needed a new clutch. I took it all apart and the clutch was brand new.
The transmission was having a hard time going into second and first ( I never drove it, I let the wife decide when we were buying it )
so I took the transmission top cover off and took a look inside, everything looks ok to me, I can even slide the gear into 2nd.
Does that mean nothing?
What the hell do I do?
buy a new synchronizer?
or another transmission?
I already bought another transmission and it was half full of water when I drained the oil, so I assume it's toast, but atleast I can use the input shaft from it.
one of the gears for 4th or 3rd (near the bottom of the case) has half of a tooth missing, would this be a problem for a stock HP engine? (5.0)
http://img21.imageshack.us/img21/4969/photo0758q.jpg
http://img51.imageshack.us/img51/1699/photo0754a.jpg
Old Aug 8, 2010 | 10:53 PM
FordF-250_460
any transmission experts?
how tough is it to disassemble these transmissions?
just so I know what I'm getting into.
can anyone point me towards a better forum?
Old Aug 8, 2010 | 11:05 PM
85e150's Avatar
85e150
How is the clutch pedal, linkage, clutch master mount, line and slave mount?
A worn synchro will grind, but get into gear eventually.
The one full of water, can you take it back? As for the broken gear, only if you are trying to make a vehicle work in the face of an enemy invasion would you put that back together.
Taking them apart is the easy part. Putting it back together right, that's the trick.
A rebuild kit can be had for about $150, and you can get a blown up diagram from here:
http://www.motivegear.com/pages/cata...TranCat003.pdf
Old Aug 9, 2010 | 12:08 AM
phoneman91's Avatar
phoneman91
Is the T18 hard to get into all gears?? Is it hard to get into gear just when the engine is running?? Or is it hard to get into gear when the engine is off?
Old Aug 9, 2010 | 05:19 PM
FordF-250_460
can't return the one full of water, got it off craigslist. It's probably salvagable, but won't work with my truck if I don't pull it apart and swap the tail shaft. and I'm not looking for a big project.
the transmission that came out of the truck never grinded, it just didn't want to go into gears. 3rd and 4th shifted fine, that's also at higher speeds though. I can't remember if it was hard going into gears with the engine off, I'll go assemble the top real quick and try.
clutch master cylinder, hose, firewall, etc is all new or solid. last owner replaced all of it, probably trying to fix this problem
Old Aug 9, 2010 | 05:35 PM
FordF-250_460
shifts into gears fine with the engine off.
Also goes straight from 1st to reverse perfectly and vice versa.
Old Aug 10, 2010 | 03:11 AM
phoneman91's Avatar
phoneman91
Is that a sign of a clutch not fully releasing???
Old Aug 10, 2010 | 01:17 PM
85e150's Avatar
85e150
That would be my guess, so a recheck of all that new clutch stuff would be in order. Not the first time that's happened.
Old Aug 10, 2010 | 02:05 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Pilot bushing/bearing bad?
Old Aug 10, 2010 | 03:41 PM
FordF-250_460
no, but you can see in the pic that the tip of the input shaft has a chunk missing.
the front input shaft bearing doesn't have anymore play than the other transmission.
I'll pull the shaft off of the rusty transmission and see how hard it will be to swap, then if I can, I'll do that and just install the transmission and re-check the clutch system
rolsen333
May 19, 2015 10:14 AM
Notmeofficer
Jul 22, 2012 05:24 PM
Duct Tape Racing
Offroad & 4x4
Apr 20, 2011 02:07 PM
Skip1970
May 21, 2010 07:58 PM
TheBigBee
Feb 8, 2010 10:09 PM
