Brake Bleed Kit
Old Aug 7, 2010 | 08:09 AM
Orezona's Avatar
Orezona
Brake Bleed Kit
Which one do you use/recommend?
Thanks in advance
Old Aug 7, 2010 | 08:26 AM
TinyWonder's Avatar
TinyWonder
I'm a rookie when it comes to bleeding brakes on my PSD but I've done it several times on my dirt bike. I've got a Mighty Vac. There are serveal different models. The one I ended up with was under $40, hand opperated with numerous attachments/adaptors. Available at most auto parts stores. I think that I got mine at Harbor Freight locally.
I sure wish that I had it when I did my clutch hydraulics a year ago.
TinyWonder
Old Aug 7, 2010 | 08:36 AM
Orezona's Avatar
Orezona
That is the one I'm looking at.
Old Aug 7, 2010 | 08:57 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Humm, I just put a hose on the bleeder and the end of the hose in a bucket, then open the bleeder and let it bleed. I make sure the fluid tank stays full. I do this to all the wheels and never had a problem.
Old Aug 7, 2010 | 09:59 AM
BillyBob69's Avatar
BillyBob69
I use the neighbor kid to press the pedal and just keep checking the reservior. (sp) with a little bottle and tube attached to the bleeder.
I have looked at the one man bleeders and there has been a couple of times I could of used it but the kid or the wife, works pretty good for me.
Old Aug 7, 2010 | 11:02 AM
miller_feed
I don't press the pedal, I just let it gravity drain and keep the reservior full.
Old Aug 7, 2010 | 12:11 PM
spdmpo's Avatar
spdmpo
I gravity bleed mine most of the time too. If the wife or child or neighbor is around I'll have them push the pedal for me. I tried that Mityvac and have one, I personally find the effort of cleaning it and hooking it up isn't worth it.
Pressure bleeding is a better way than vacuum bleeding.
Old Aug 7, 2010 | 12:18 PM
Nick 99's Avatar
Nick 99
This is what I use Pressure Brake Bleeder
I have known a few guys that will make one out of a Plastic garden sprayer but I like the ease of the store bought bleeder, besides I got the one with all the adapters for various vehicles.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
