crossmember ?
Old Aug 7, 2010 | 04:06 AM
tardster's Avatar
tardster
crossmember ?
I wanted to know how much of a differance there is if I removed the crossmember that is right under where the motor and tranny come together. It is not being used for anything other than being in the way for my headers. Here is a pic of the one I'm talking about...
Old Aug 7, 2010 | 05:32 AM
55F250's Avatar
55F250
AirForceVet
Crossmember
There has been a lot of discussion here about that, if you do a search you'll see what I mean. I had the same problem with header clearance with the
351c, I cut it out. The crossmember served two purposes, engine mount and structual support, the frame was designed to flex.
Old Aug 7, 2010 | 08:37 AM
55 f350's Avatar
55 f350
my cuz billy's 53 had that one and the front v8 xmember cut / notched out { the trans one removed } and needless to say he has had to straighten it , box it , and added some xmembers too replace them . the frames might be made to flex but too much gone and you end up with a pretzel and doing a lot of repair and welding !!!!!!!!!! move it , or put another in further back , or modify it to clear would be my opinion .
Old Aug 7, 2010 | 09:09 AM
ZOOT's Avatar
ZOOT
CROSSMEMBER
If you have a stock front end, fab some kind of crossmember to prevent too much flex. The new drivetrain has a lot more power than stock. If you have a Mustang II type, you'll have to box the frame where the crossmember was attached as well as fab a crossmember. With an IFS you want least amout of flex. Hope that helps
Old Aug 7, 2010 | 01:11 PM
55F250's Avatar
55F250
AirForceVet
Crossmember
I didn't intend to imply that it was ok to do away with the crossmember/structual support because the frame was meant to flex, it was made to flex with the crossmember in place, it goes without saying if you take it out it will flex more.
Old Aug 7, 2010 | 01:23 PM
tardster's Avatar
tardster
There is another crossmember for the tranny mount just abit further back. You can just barley see it at the top of the arrow I put in the picture, Will that be enuff or should I go ahead and put another in here once I get the headers on? The truck was originally a V8 and I have no plans on hot rodding/racing it or anything like that.
Old Aug 7, 2010 | 01:39 PM
merc546's Avatar
merc546
For what it's worth, if you have the original front suspension then I would suggest that you modify/or replace it with one that clears your headers. If I remember correctly the stock cross member attaches at the rear spring mount. I think it would be a good idea to keep that arrangement. Now if you have a IFS then you can remove it because you are replacing it with the IFS cross member.
Chuck
Old Aug 7, 2010 | 02:56 PM
52 Merc's Avatar
52 Merc
There is another crossmember for the tranny mount just abit further back... Will that be enuff
It depends. If you notice on all the factory members, not only do they attach both sides together, they also connect the upper and lower frame rail webs together. Too many homemade or aftermarket crossmembers fail to do that, and really don't put back the strength necessary for correct functionality. So if your trans crossmember just sits/bolts on the bottom part of the frame rail web, it's not going to take the place of the factory member you want to remove.
