428 How do you know??
Old Feb 14, 2003 | 03:05 AM
rwt's Avatar
rwt
I am sizing up this 74 F250 4x4 with a 428. How do I know this is a 428 and do you think this truck is worth $4000.00 Canadian. The box is fairly rusty but the drive train is solid. 4 speed, propane fuel, ps, pb, ac, dana posi tracks, hydraulic winch, line locks. Any input would be helpful, for I have not owned a Ford truck before.
Old Feb 14, 2003 | 11:12 AM
Purely Ford's Avatar
Purely Ford
Measure the stroke with a wooden dowel. You should get around 3.984 inches. There is no way to know if the bore is a 428 spec bore of 4.13 without disassembly. Are you positive the engine is an FE?
Old Feb 14, 2003 | 11:44 AM
beartracks's Avatar
beartracks
I'm not certain but I seem to remember those engines comming with a 4V carb that was offset or twisted on the manifold.
Old Feb 14, 2003 | 05:48 PM
fordfan428's Avatar
fordfan428
The "sidewinder" intake will fit just about any FE..The only way to tell if you have a 428 for sure is to pull a head and measure the bore along with the stroke..Of course someone could have tried to make a 428 and overbored another FE which is not really a good idea as it can make the cylinder walls too thin..But if you do have the 428 rotating assembly you could always make a 410 if the block is bad..JMO..If you have more ?'s on FE's you should head over to the board, lots of people that know their stuff over there..
Old Feb 16, 2003 | 01:29 PM
Scot's Avatar
Scot
A typical FE flexplate has little or no large holes in it. The 428's have triangular holes in it that look like pizza slices. The 428 balances different than the rest of the FE's.
428HIGHBOY
Apr 8, 2007 09:30 AM
my79f
15
Sep 13, 2005 01:15 AM
DavidCOH
Jan 22, 2005 10:49 PM
Brad Brown
Jan 9, 2005 06:13 PM
67 428 Fairlane Ranchero
Jan 12, 2003 07:16 AM
