6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Won't start
Old Aug 6, 2010 | 09:36 PM
markt1993's Avatar
markt1993
Won't start
2008 250 with 54000 miles. Truck was running perfect. Get in it to start it up and nothing happens. Dash lights come on like normal but the motor doesn't turn over. Just like a dead battery. Ford road side comes and picks it up. They take it to the dealer and the dealer calls me and says it started up fine with them. But they want to keep it over night and try it in the morning to see if it acts up then. Later the next day they call and say I need 2 new batteries. One showed 140 cold cranking and the other was 14. And they are not covered under warranty. They call and tell me it is ready and they charge me 270.00 for the 2 batteries. I pay go get in it and it will not start, same problem. I go get the tech and he plays with it and it finially starts up. So they give me a loaner and say they will call me.
A day goes by and they call say it is ready but once again want to keep it over night to make sire nothing is maybe daring the batteries. They say the problem is that the batteries got low and it reset the relays. Then they put the new batteries in they forgot to program them. Give me a paper saying it was code P1260 saying it was the passive alarm system. Well I drive it home and it runs perfect the. Go out to eat and on the way home check engine like flashes along with the chime saying pull over safely now. Then the engine shut off. And doing the same as before. Turn the key on and everything works but it will not turnover.
Any thoughts? Thanks
Old Aug 6, 2010 | 10:27 PM
bnmccoy's Avatar
bnmccoy
Do you have a second key; maybe the security part of the key.
Bob
Old Aug 6, 2010 | 10:31 PM
markt1993's Avatar
markt1993
They gave me a new key. They said my spare at home wouldn't work anymore. I had both keys with me but neither would start it.
Old Aug 6, 2010 | 10:38 PM
whitre's Avatar
whitre
Check the ground wire from the firewall to the engine. It may be loose.
Old Aug 6, 2010 | 10:44 PM
markt1993's Avatar
markt1993
Wouldn't the dealer have checked all that? Is gone now they towed it already.
Old Aug 7, 2010 | 06:41 AM
senix's Avatar
senix
Just because of new batteries does not mean you need new keys. There is something else at play here.
Sounds like a wiring harness issue of some kind.
Old Aug 7, 2010 | 08:04 AM
markt1993's Avatar
markt1993
Well they say the reason for the new key was that for them to reprogram the relays that had to have 2 keys but I only left them one. So they used the key I had plus the new one they gave me. But say my spare at home will no longer work. I don't understand that because it doesn't look like these keys have the chip in them.
Old Aug 9, 2010 | 08:14 AM
fg250's Avatar
fg250
sounds like a short in the wiring harness. I talked to a guy that had similar problem. Parked the truck at night, next morning wouldn't start, took the dealer a few days but figured out the short and replaced wiring harness, don't know which one or where specifically the short was though.
Old Aug 9, 2010 | 01:31 PM
overthehillbill's Avatar
overthehillbill
My '08 didn't have a chip in the key. Spare key was just $1.50 Walmart copy.
Old Aug 9, 2010 | 03:40 PM
markt1993's Avatar
markt1993
Update
It's fixed so far. Dealer says the problem this time is unrelated to last. This time it was a EGT sensor. Basically told the computer the to exhaust was to hot and killed the engine. It would start after it cooled but only run a mon or two.
The dealership says they drove it 75 miles with no problems. Plus they topped it off with fuel thankfully.
Old Aug 9, 2010 | 06:26 PM
senix's Avatar
senix
EGT sensor is rare but a couple have had that issue.
Hope that is the end of it.
Old Aug 9, 2010 | 06:30 PM
markt1993's Avatar
markt1993
Me too. So far all is well.
Coloradogirl
Electrical Systems/Wiring
Jan 9, 2015 06:49 PM
lundman
6.7L Power Stroke Diesel
Aug 30, 2014 10:03 AM
02PSD4ME
2011 - 2019 Explorer
May 15, 2012 10:21 AM
n2ojoe
Dec 31, 2010 05:24 PM
baumer64
Feb 22, 2007 10:10 PM
