I checked all of the harness no lose connection nor chaffing. I also pulled oil filter and had my ole lady crank on it for a sec and very little oil was filling up and had bubbles does that mean anything?
By depressing the drain valve, you can get a better look at the oil flow. IMO, you still do not know how much the LPOP puts out under pressure, but it will tell you that you have an LPOP problem if it does not flow much at all.
