Keyless Access Codes
Old Aug 9, 2010 | 11:59 AM
  #31
perryg114's Avatar
perryg114
If you are paranoid you can pull the plug on the external key pad.
Thanks for all the help folks.
Perry
Old Aug 11, 2010 | 03:57 PM
  #32
miggun's Avatar
miggun
Originally Posted by jcobb124
This is what I followed and found mine. You will a flash light and a small mirror then tie your self into a pretzel!!
Its not really that bad, but it did work!!
Hello Thanks for the information!
But in my 2006 F-350 there is a isolation in front of the box so I can't read the code! Now I bought this nice tool, because I can use it for my Harleys too. And I had found the code! I think in the U.S. you can buy tools like this too.
BATAVIA Videoskop mit 900 mm Schwanenhals bei eBay.de: Mess- Prüftechnik (endet 03.09.10 15:31:00 MESZ)
I hope this can help some people who search the code!
Old Aug 29, 2010 | 02:00 PM
  #33
Z06PSI's Avatar
Z06PSI
2005 Navigator. Just reset the personal code which was 11111 and retrieved my factory code as well. Underneath the right side kick panel tucked up and behind the wiring harness to the top left of the passenger fuse panel.
perryg114
May 23, 2014 03:07 PM
perryg114
Modular V10 (6.8l)
Oct 25, 2013 03:28 PM
perryg114
Sep 22, 2011 03:15 PM
logginhard
May 15, 2004 11:23 PM
