Keyless Access Codes
Old Aug 7, 2010 | 09:40 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by perryg114
How do I change the personal code to something else without the master code?
You can't. You need the master code to do it.
How do you know you guessed the previous owners personal code and not the master code?
Stewart
Old Aug 8, 2010 | 12:00 AM
gr8scott72's Avatar
gr8scott72
How do I change the personal code to something else without the master code? The personal code was obvious and is not secure that way. It is not secure the way it is considering I guessed it in one try.
Perry
You don't. You must have the master code first. Then you can reset the secondary code to whatever you want.
Edit: didn't see Stewart's reply on the next page before I typed this.
Old Aug 8, 2010 | 06:22 AM
perryg114's Avatar
perryg114
Well I may have to disable the remote entry till I can reset the codes.
Perry
Old Aug 8, 2010 | 09:37 AM
gr8scott72's Avatar
gr8scott72
Perry
Well, is it the primary code or the secondary? If it's the secondary, just keep using that list until you find the primary number and then reset the secondary.
Old Aug 8, 2010 | 10:32 AM
jcobb124's Avatar
jcobb124
I gave up on the hack, I found the hidden sticker under the dash! Wooo HOOO!
Old Aug 8, 2010 | 06:05 PM
perryg114's Avatar
perryg114
Where under the dash.
Perry
Old Aug 8, 2010 | 06:08 PM
jcobb124's Avatar
jcobb124
This is what I followed and found mine. You will a flash light and a small mirror then tie your self into a pretzel!!
Its not really that bad, but it did work!!
Old Aug 8, 2010 | 06:10 PM
jcobb124's Avatar
jcobb124
Sorry forget this pretty important pic!
Search this forum for keyless access code, and you'll find this guys entire thread.
Old Aug 8, 2010 | 08:20 PM
perryg114's Avatar
perryg114
So which of those numbers is it? A door code ends with 1 or 2 but does the master code need to if all it does is give you access. So what is the proceedure for resetting the user code using the factory code?
Perry
Old Aug 8, 2010 | 08:24 PM
jcobb124's Avatar
jcobb124
In the picture the "35797" is the master code.
To program your personal code, enter the master code, then press the 1/2 button within 5 seconds, then enter your personal code.
Old Aug 8, 2010 | 08:47 PM
Stewart_H's Avatar
Stewart_H
Perry, why are you assuming the code ends in 1 or 2? It can end on any number.
Stewart
Old Aug 8, 2010 | 08:49 PM
Stewart_H's Avatar
Stewart_H
Jared, you might wanna think about obscuring your number bro.
Stewart
Old Aug 8, 2010 | 08:50 PM
  #28
jcobb124's Avatar
jcobb124
Yea I'm good. It's a generic google pic.
Old Aug 8, 2010 | 08:55 PM
  #29
Stewart_H's Avatar
Stewart_H
AH! Ok.
Stewart
Old Aug 9, 2010 | 08:29 AM
  #30
jdadamsjr's Avatar
jdadamsjr
Actually, it's SOMEBODIES code
and the fact that ANYONE can try the hack does not bode well for all the Christmas presents stored in the back of the Ex
