Engine Ratings - Chassis Cab Vs. Pick Up
Old Aug 6, 2010 | 02:02 PM
blueheron's Avatar
blueheron
Question Engine Ratings - Chassis Cab Vs. Pick Up
According to the specs. on page seven of the Coffee table Book:
Diesel Technician Society
The engine in the chassis cab is rated
at 300 hp @ 2800 rpm and 660 ft.-lb. @ 1600
while the pick up is rated
at 390 hp @ 2,800 rpm and 735 ft.-lb. @ 1,600 rpm
Please pardon my ignorance, but what is different about the engines which produces the different ratings? I dare say it's in the software, but what is it that the software does?
Old Aug 6, 2010 | 02:13 PM
jfritz_drfritz's Avatar
jfritz_drfritz
fundamentally it comes down to the emissions certification process. It would seem that the chassis cabs model follow a more stringent emissions certification process. My understanding is that because of the variable configuration that a chassis cab could have once it leaves the factory, the tuning must be conservative enough that the emissions requirements are met however the truck is used. Thus the lower state of tune allows a large safety margin for emissions compliance.
Old Aug 6, 2010 | 10:06 PM
BrockwayMT's Avatar
BrockwayMT
Another concern in addition to emissions is duty cycle. Chassis cab truck is expected to work at a higher load at a given percentage of time. Or spend a higher percentage of time above a given load level.
The 400hp and 800 lb-ft in a pickup is not sustainable for a long period. The engine components won't hold up and the cooling system can only hold that level of power for so long.
Duty cycle is why you see lower specific power outputs in higher duty cycle applications. 400 hp from 6.7 liters is great but only in small doses. A modern 400hp truck engine is around 9 or 10 liters at typically 1800 or 2100 rpm. Before electronic controls 400hp would probably be 14 liters (in a 4 stroke). But this 10 liter truck engine can sustain a higher percentage of it's rated power for a longer period of time. It also has a much larger radiator to support this duty cycle.
Old Aug 7, 2010 | 11:11 AM
Smokin_cache's Avatar
Smokin_cache
So my chassis cab was just delivered. Will my truck be upgaded to the specs of 400 and 800?
Old Aug 7, 2010 | 11:21 AM
PowerStrokeHD's Avatar
PowerStrokeHD
As you would expect the software is different, but the biggest difference is the turbo set-up. The pickups use a single-sequential turbo while the chassis cabs use a single-stage turbo.
Old Aug 7, 2010 | 11:23 AM
PowerStrokeHD
No, it will not...
Old Aug 7, 2010 | 11:26 AM
Smokin_cache
I have found nothing that states they use different turbos. Where did you find that information?
Old Aug 7, 2010 | 11:43 AM
PowerStrokeHD
If you look at the Coffee Table Book it shows the two different turbos used. The one on the bottom of page 38 is the pickup turbo and the one on the top of page 39 is the chassis turbo...
Old Aug 7, 2010 | 11:50 AM
Smokin_cache
And there it was!! Thanks
I feel kinda ripped off! I have 25% less power than the guy sitting next to me. Pitiful
alarsso444
Dec 14, 2015 12:03 AM
49willard
Apr 23, 2013 10:02 AM
whopp
20
Oct 18, 2008 08:23 PM
robprime
21
Oct 15, 2007 08:44 PM
jschira
All Things Towing
31
Nov 26, 2006 07:38 PM
