Morse code under steering column
Old Aug 5, 2010 | 10:12 PM
chrischaugen's Avatar
chrischaugen
Just went to my sons football practice, and noticed when I shut the truck off, there was a clicking sound, sounding a little like morse code. I pulled the panel off under the steering column, and the noise got louder, but I couldn't pinpoint it. I accidentally pressed on the brake pedal, and the clicking went away. I'm going out again now that I'm at home to see if I can find the source. Does anyone have any ideas of what I may be looking for?
Thanks in advance for any and all suggestions!
Old Aug 5, 2010 | 10:27 PM
bismic's Avatar
bismic
Sounds like a weak relay chattering to me.
Old Aug 5, 2010 | 10:35 PM
chrischaugen
Any idea where I can find or look for said relay? I'm sure with my luck it's stuffed way back up underneath the dash huh?
I pulled all the fuses that deal with the braking system, and none of them stopped the chatter. Is the brake pedal maybe just a coincidence? Or is this potential relay a part of the braking circuitry?
Old Aug 5, 2010 | 10:37 PM
bismic's Avatar
bismic
When it does it again, you can feel around for the "hot" component.
Old Aug 5, 2010 | 10:59 PM
chrischaugen
OK, I found the relay that is chattering. It is right behind the lower middle panel, the one with the pedal adjustment switch, cup holder, etc. I've taken out the 3 bolts on the bottom, the 2 bolts holding the panel with the 'hangar' thing on it, and the 2 bolts that you see when you pull out the cup holder. Which bolts am I missing? The bottom is loose, but I don't want to pry too hard to get the top out in case I'm missing something. I'm sure someone has taken this panel off...any step by step instructions?
Kinda doing this to myself...sorry...
Old Aug 5, 2010 | 11:05 PM
sammy77's Avatar
sammy77
Hopefully it don't get to hot...
I dont wanna see Bismic post another 6.0 in flames
Old Aug 5, 2010 | 11:31 PM
chrischaugen
I found the relay I believe to be causing the problem. Not sure if it's the part number, but does F65B-13350-AA 2(4) x 32CP-12v DOT SAE) sound familiar? I did a google search on it, and came across an FTE website discussing it. The people did what I did, remove it, and the buzzing stopped. They bought a new one, installed it, and the buzz was still there, so they took it to Ford, and Ford found a bad turn signal/ multi-function switch.
Is there any way that I can verify this before I go to purchase a new one?
From what I understand, the multi function switch is in the steering column...has anyone done this themselves, or is this something that I need to make an appt with Ford to take care of?
Thanks again for all your help!
Old Aug 5, 2010 | 11:38 PM
sammy77's Avatar
sammy77
I have never had a issue with this relay you reffering to, but I can tell you its not hard to change the multi-function switch. It is the turn signal/wiper. Three phillips screws, remove the column covers and a torx bit and you're good to go.
Old Aug 5, 2010 | 11:47 PM
chrischaugen
Sweet...I'm going to go give that a shot now.
Now once I do that, what does the switch look like? Can I disconnect it, plug the blue box back in, etc...I guess what I'm asking, once I get to the switch, is there a way to make sure that it's the switch that's bad, or the 'blue box'??
Thanks Sammy77!
Old Aug 6, 2010 | 12:27 AM
chrischaugen
I've got the steering column bottom cover off, but can't get the top one off due to the shift lever. Can someone please describe what the multi function switch looks like? I see a gray connector going into something right next to the turn signal / wiper lever. Is that it?
Old Aug 6, 2010 | 12:51 AM
bismic's Avatar
bismic
I just replaced the multifunction switch in my sons 7.3L. It is the turn signal lever and the switch - all as one unit.
http://www.thefind.com/cars/info-tur...unction-switch
http://www.f150online.com/forums/ele...on-switch.html
brian42
Feb 1, 2017 04:44 PM
Apocalypse
Dec 31, 2014 01:25 AM
drumsk
Nov 26, 2013 10:08 PM
FSJ-EARL
Nov 25, 2013 07:40 PM
