Brush Guard Installation help
Old Aug 5, 2010 | 08:52 PM
muddycreekoutfitters's Avatar
I got a pretty good deal on a used grille guard for my 01 F250 SD CC 4x4. It's not the front bumper replacement, just the grille guard.
From looking at it, looks like all I have to do is pull out the two bolts to the outside of the tow hooks, and set it in place and put the bolts back in. Is this right? Surely it isn't that easy.
Thanks.
Old Aug 8, 2010 | 10:58 PM
Coskid's Avatar
Coskid
Without knowing the exact model you have I can't say for sure but yeah its just about that easy usually. Some guards require that you replace the existing bolts with some that are just a bit longer so that you can get the guard secured properly.
Old Aug 9, 2010 | 02:54 PM
rockstate45's Avatar
rockstate45
I did a brush guard install on an F150 (about '05) and it went smoothly.
Look and see where the brush guard attaches, and then go from there.
What manufacturer is it? It's possible it might have to attach to the bumper somewhere. The westin I did on hte f150 attached at 4 places, and so does the Ranch Hand I ahve on my Tundra.
-rockstate
Old Aug 9, 2010 | 07:39 PM
ReAX's Avatar
ReAX
It typically is on the superduty. Drop four bolts, hook up two brackets, set the brush guard and tighten every thing back up. Don't tighten down the bolts to the bump until you have snugged the brush guard to the brackets, they will probably need some tweaking to get them lined up.
hivoltj
Nov 2, 2020 05:58 PM
OldDrty
Apr 22, 2015 03:31 PM
revans9295
WTB - Parts & other
Apr 14, 2014 12:31 PM
MisterCMK
Sep 21, 2010 07:22 AM
