now what?
Old Aug 8, 2010 | 09:57 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
And if you were to pull your fuel filter after it's set all night I suspect you'll find it less then full...
That would be drain back caused by air intrusion, most likely the fuel return lines, tees and o-rings ... Like I said previously, the Pensacola o-rings in the four kits I got were all junk.
I suggest investing in good o-rings, pulling the return systems apart, cleaning and reassemble with the good o-rings.
-Enjoy
fh : )_~
