shocks
Old Aug 4, 2010 | 11:32 PM
chpro's Avatar
chpro
shocks
Im a landscaper so theres a dump insert in the truck and i USE it alot wondering which shocks yinz perfer? There is no lift or suspention upgrades.
thanks to all
Old Aug 4, 2010 | 11:58 PM
big poppa's Avatar
big poppa
Don't know what you mean by dump insert but as for shocks covering all four corners the Bilstiens are Heavy duty and were a nice choice to my setup, great shocks and with a great warranty.
Old Aug 5, 2010 | 06:48 AM
riverrat41's Avatar
riverrat41
Pop's is right.Bilstein's are good but if you have an Auto zone close they have heavy duty Gabriels that folks here are running that work good as well...Warranty too.
Old Aug 5, 2010 | 08:06 AM
kccatpower's Avatar
kccatpower
if you are running a dump bed and are hauling material in the back alot i would look into adding air bags in the rear.
Old Aug 5, 2010 | 08:21 AM
riverrat41's Avatar
riverrat41
I second what Grady said.They work well.
Old Aug 5, 2010 | 10:06 AM
TinyWonder's Avatar
TinyWonder
No disrespect intended but he's asking about shocks. Air bags are great (I even have a set on my rear axle) but do something quite different than the shocks.
Bilstiens appear to be the "go to" shock of choice on FTE. I've got a set of HD shocks from the regional tire emporum and they work great. I think that they are KYB but I'd have to check the receipt to make sure. I've had them for about 3 years and they seem to be doing their job nicely.
Old Aug 5, 2010 | 04:13 PM
chpro's Avatar
chpro
thanks guys i have been looking at the air bag system but the shocks do do a diffrent thing and it sounds like the bilsteins are the ones i will go with theye have been recomended by lots of ppl. thanks again.
Old Aug 5, 2010 | 04:21 PM
Bonanza35's Avatar
Bonanza35
What ever you do don't put Monroes on. I just did there truck shocks and they suck. They are life time guaranty but suck. When I was younger they where the shock to stand by, But not for these trucks, Bilsteins are more but I bet well worth it"
Old Aug 5, 2010 | 04:40 PM
megawatt00's Avatar
megawatt00
I am sure that he meant in addition to and not in replacement of.
Old Aug 5, 2010 | 04:53 PM
kccatpower's Avatar
kccatpower
no disrespect taken. the only reason i thought it might help is that he has a dump bed. on my friends truck f-450 with a flat bed dump we noticed when trying to use the bed to spread gravel if you got on a slope or the load shifted that side of the truck would squat and cuase the gravel to pour to that side. after installing airbags the problem was not as bad and really helped the ride out when loaded. not sure if he uses his truck in this application or if he wants better ride loaded or unloaded. just trying to throw out options and ideas.
Old Aug 5, 2010 | 04:56 PM
megawatt00's Avatar
megawatt00
I am starting to sniff around for some myself. I know that Firestone is a big name any other's that I should look at?
Old Aug 5, 2010 | 05:25 PM
TinyWonder's Avatar
TinyWonder
Duh! I should have thought of that. I've got the Firestones on my truck with the in-cab compressor controls. It's really nice and convenient. You don't even need to get out of the truck to adjust the pressure up or down. Just don't flip the switch with your dog in the cab.
TinyWonder
