VSS Location 94'F250
Old Aug 24, 2010 | 04:13 AM
subford's Avatar
subford
Yes it is.
Old Aug 24, 2010 | 04:30 PM
jmpluta's Avatar
jmpluta
that black box (rectangle about 5 inches long) ?
Old Aug 24, 2010 | 05:46 PM
subford's Avatar
subford
Here is an image, located at C-1:
Old Aug 24, 2010 | 06:21 PM
jmpluta's Avatar
jmpluta
Bill, do you think that will take care of the hard shifting, no speedo or does that just take care of the abs light? Thanks.
Old Aug 24, 2010 | 07:52 PM
jmpluta's Avatar
jmpluta
I removed the abs sensor, and that shut off the abs light but the hard shifting in reverse and drive are still there(speedo still not working). Any ideas???Thanks, Mike
Old Aug 25, 2010 | 06:06 AM
subford's Avatar
subford
Did you remove the rear end sensor or unplug the RABS module?
If you unplugged the module and replaced the sensor in the rear end and checked the wiring under the truck and it and all the fuses are OK and still have the problem then the problem is in the rear end or a bad PSOM.
Old Aug 25, 2010 | 10:48 AM
jmpluta's Avatar
jmpluta
I unplugged the RABS module. Is there a more detailed diagram of the PSOM location? Also do I have to reprogram this or just replace it?
Old Aug 25, 2010 | 09:36 PM
jmpluta's Avatar
jmpluta
I just replaced the PSOM. I still have no speedo and very hard shifting. Will re-programing the PSOM that I just installed have any effect with the problems I am still having ?
Old Aug 26, 2010 | 07:13 PM
subford's Avatar
subford
If it was a used PSOM it may have been bad, else you may have a bad tone ring inside the rear end.
Old Sep 11, 2010 | 08:45 PM
jmpluta's Avatar
jmpluta
So I finally got my speedo,abs, hard shifting, and, odometer problems all taken care of. After looking high and low, trying this and that. I took my 94 F150 to a guy who deals with electrical problems. It turned out to be the VSS and one of the wires was pinched. It cost me $ 250.00, but after all the hassle , the money I spent was well worth it. Thanks to everyone who helped lead me in the right direction. I would like to give a great big THANKS to Bill (Subford). I appreciate that you put up with all the questions!!
02whtmax
May 31, 2024 09:22 AM
02whtmax
Modular V10 (6.8l)
Oct 29, 2011 04:39 PM
1badshovel
May 16, 2011 11:19 AM
joelswork
Nov 4, 2010 11:07 PM
ledgend
Nov 19, 2006 10:41 PM
