Modular V10 (6.8l)
01 F250 VSS problem
Old Oct 29, 2011 | 01:39 PM
02whtmax's Avatar
02whtmax
01 F250 VSS problem
Heres my problem, and its driving me crazy. I've got an 01 f250 with the v10 4x4. The speedometer is not working and the o/d light is flashing, but i have no shifting issues. Pulled the codes and im getting a p0500 (VSS sensor A). Both sensors (one on rear diff, and one on the tranny have been replaced). I know these sensors can sometimes be bad from the get go but im at a lose. Any ideas? To be sure a bad instrument cluster would not cause the check engine light to come on, and the o/d light to flash? Any ideas?
Old Oct 29, 2011 | 01:58 PM
dkf's Avatar
dkf
What scanner did you use to pull the codes? Tuners and cheap scanners do not always show all the codes that the proffessional readers the dealers and pro shops have, especially trans codes.
Old Oct 29, 2011 | 03:58 PM
02whtmax's Avatar
02whtmax
yes, i did use the cheap one from autozone. didnt know would not read all the codes, will have to see if i can get ahold of a pro model
Old Oct 29, 2011 | 04:39 PM
02whtmax's Avatar
02whtmax
Also forgot to mention, my clock spring is bad too. But surly this would not effect any of my issues would it?
woodduck17
Jul 29, 2009 10:48 AM
bubbies24
Mar 16, 2007 10:03 AM
gui88ford
1997 - 2003 F150
Dec 22, 2005 05:37 AM
manasota
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 13, 2005 08:47 AM
WildTurkeycj8
Modular V8 (4.6L, 5.4L)
Apr 18, 2004 04:26 AM
