1978 - 1996 Big Bronco
lock out hub question.
Old Sep 16, 2009 | 07:08 PM
drunkdave's Avatar
drunkdave
while trouble shooting my noise in what I thought was the rear, I removed the rear drive shaft, locked the front hubs and attemted to drive my bronco out of the garage. no dice, with the transfercaser in 4hi or 4lo, all i got was a cliucking noise, the front drive shaft was spinning. I'm thinking my hubs are junk, waht do you all think?
Old Sep 16, 2009 | 07:10 PM
greystreak92's Avatar
greystreak92
If the front driveshaft spins in a 4WD t-case gear and the front wheels won't drive, then hubs are the next logical failure point.
Old Sep 16, 2009 | 07:13 PM
ranger429's Avatar
ranger429
All depends how bad the clunking is but it could be ring and pinion as well. I'd check the simple stuff first, the hubs aren't that hard to check.
Old Sep 16, 2009 | 07:47 PM
drunkdave's Avatar
drunkdave
it was more of a clicking noise than a clunk, if thats any help. how would I go about checking the hubs?
Old Sep 16, 2009 | 08:08 PM
g_k50's Avatar
g_k50
"When the transfer case is to be shifted into the position for driving the front axle, the pointer on the center bar of the hub must point to the pointer over the word LOCK on the Hub Lock Cap. If the clutch teeth do not engage with the **** turned to this position, the clutch teeth are butted and a slight movement of the wheel in either direction will complete the lock. The front axle will now drive the wheels. Do not operate the four-wheel drive with the hubs disengaged."
That's from my 1990 Truck Service Manual, if you're lucky that's what your problem is.
Your hubs aren't turned in. If they are, I'll continue looking for a solution to your problem. I've solved about all the problems with my bronco, other than it's a POS, Looks like a POS, runs great. Just tightened up the transmission pan that was leaking.
Old Sep 16, 2009 | 08:18 PM
drunkdave's Avatar
drunkdave
I just checked the pointer on the hubs are pointed at "locked" on both side. I rocked the bronco a little, while watching the front shaft, the front shaft did not move.
Old Sep 16, 2009 | 09:55 PM
g_k50's Avatar
g_k50
does the axle shaft rotate at the wheel when you have the hub lock off as you turn the front driveshaft?
Old Sep 17, 2009 | 12:40 PM
drunkdave's Avatar
drunkdave
rolling the truck back anbd forth watching the axle shafts they turn with the wheel. whith the transfer case in four wheel drive, and the truck running and in drive, the drive shaft and left (drivers side) axle shaft spin. Looks like I will be ordering new lock out hubs this afternoon.
twags6
24
Jan 5, 2017 08:24 AM
curioduo
Aug 6, 2015 09:22 PM
ANigrelli132
Jun 24, 2014 10:38 AM
SSSimon
Australia Chapter
19
Jan 1, 2014 01:23 AM
shad9876
Mar 27, 2010 11:23 PM
