toggle switch wiring
Old Aug 4, 2010 | 12:47 PM
alhauger's Avatar
alhauger
Okay guys, i cant figure for the life of me how to get my damn reverse lights workin the stock way and ive tried it all, so it's toggle switch time. I will be the first to admit im not the most electrically sound guy, but i am capable with a shove in the right direction. The shove i need this time is a brief description of the wiring for such a toggle switch or perhaps a diagram. I plan to run through the existing fuse, since it currently is not getting power. I also plan to use the existing lights for now, i will probably upgrade later. Any help you can give would go a looooong way in alleviating my frustrations. thanks. 1986 F150 XLT.
Old Aug 4, 2010 | 12:58 PM
smashclash's Avatar
smashclash
run wire from fuse to toggle switch. from toggle switch run a wire to the bulb. (i'd assume ground is always hot). done.
Old Aug 4, 2010 | 01:14 PM
alhauger's Avatar
alhauger
Im not getting any power to the fuse in the first place, so ive gotta run wire from the fuse to the battery first. Should i run off the starter relay, or right off the battery? Im thinking it would be hot from battery to fuse, then to switch, back to bulbs, then ground out of bulbs and directly to frame. Am i missing anything?
Old Aug 4, 2010 | 01:48 PM
Franklin2's Avatar
Franklin2
If you are going to do this, why not just get two fuse taps, put one tap under the key in run hot fuse like for the blower motor, and the other fuse tap under the dead back-up fuse. Then make a small jumper and hook the two fuse taps together. Then the back-up fuse will be powered and the back-up lights will work then correct?
Old Aug 4, 2010 | 01:56 PM
alhauger's Avatar
alhauger
You are a genius. That is the kind of solid ideas i need, i tend to overthink things and forget the easier answers. Thank you sir.
timstheman5
Electrical Systems/Wiring
Nov 24, 2014 02:33 PM
wally b
Feb 9, 2014 06:28 AM
FordBoy2012
1997 - 2003 F150
Dec 5, 2012 06:29 PM
BlueOvalBud
21
Mar 1, 2010 05:54 PM
