noise in front end
Old Aug 4, 2010 | 09:12 AM
cj7taz's Avatar
cj7taz
noise in front end
my truck is a 04 f150 with the 5.4 triton.. only mod is the leveling kit in the front. it has 75k on it...
i was just reading about a rattle a guy had on a 07 f150..
not sure if i have the same problem, but i have a noise that sounds like metal to metal, it even happens backing out of the driveway, at real real slow speeds also.. pretty much happens all the time.. it actually did it when someone was getting into the truck the other day..
so i am not sure it would be the same issue the other guy had..
i have jacked the truck up a number of time and went over the front end, i thought it was the front skid plate so i removed it, then i thought it was the plastic gas tank skid so i removed that.. both no good, still have noise.
any input or suggestions would be appreciated........
on another note i had allot of chatter in the rear when i would take off, truck has limited slip out back.. it was getting real frustrating.. so one day i decided to change the fluid, well i finally got off my butt and did it.. i also added the ford additive to and used synthetic oil.. well the problem was fixed..
Old Aug 5, 2010 | 09:52 AM
cj7taz's Avatar
cj7taz
well i took it to a shop yesterday to have it looked at and i am not sure where the noise is coming from..
it may be the rear axle..........
i am dropping it off Monday to have to checked over.. there appears to be a small leak coming from the front seal in the rear diff..
Old Aug 5, 2010 | 10:07 AM
Coskid's Avatar
Coskid
Not sure how confident you are with the shop you took it too but make sure they know you have a limited slip rear axle which requires the extra friction lube compared the regular axles on these trucks.
Old Aug 5, 2010 | 10:21 AM
cj7taz's Avatar
cj7taz
this is the only guy i would let touch my truck.....
and yeah he knows.............
Old Aug 5, 2010 | 10:37 AM
Coskid's Avatar
Coskid
OK good. Not everyone has someone like that and I hate to see something happen to someones truck that could been prevented.
Old Aug 5, 2010 | 10:50 AM
cj7taz's Avatar
cj7taz
yeah i hear ya... i was doing some reading yesterday on here and saw some real horror stories......
Old Aug 5, 2010 | 08:02 PM
70f100longbed's Avatar
70f100longbed
Does the noise go away in 4wd? You may have a bad 4x4 solenoid or a leaking hub.
Old Aug 6, 2010 | 05:41 PM
Ryan50hrl's Avatar
Ryan50hrl
My truck had a very similar rattle....ended up being the sway bar links....might be worth disconnecting them and driving around a bit......
Old Aug 7, 2010 | 06:00 PM
FORD COASTIE's Avatar
FORD COASTIE
Veteran: Coast Guard
My truck had something like this last year. Both sway bar links had to be replaced. The parts were about $82.00.
Old Aug 9, 2010 | 09:02 AM
cj7taz's Avatar
cj7taz
well just hung up the phone with the shop, it was the right side sway bar link..
thanks guys for the input...
also my rear pinon seal was leaking just a wee bit so i am going to have him look at that also......
dkk
2009 - 2014 F150
Jun 21, 2012 10:42 AM
billfortune
Jan 25, 2010 01:05 PM
dannielchackas
Dec 17, 2008 01:43 PM
MikePDX
2004 - 2008 F150
Dec 27, 2007 11:21 AM
dalfollo
Apr 4, 2004 10:56 PM
