The tach itself is probably the same, but the face (the black piece of plastic) is probably specific to the cluster, so a pickup tach probably won't physically fit into your cluster even if it's electrically compatible.
I have looked at it before..... the actual cluster is identical to the truck except for the gauge displays.... the viewing area in the dash is molded a little differently, but the clusters look to be identical.
