idi air intrusion?
Old Aug 3, 2010 | 11:14 PM
boots6868's Avatar
boots6868
idi air intrusion?
Hi guys the advice in this forum has always helped me out, my old work truck got a new problem now. If it sits overnite the next morning she will fire right up and then shut off. then you gotta crank the heck out of it then when it does fire up its kinda rough. I hate cranking it for that long its gotta be hard on batteries and starter and frankly its down right embarassing first thing in the morning. Im guessing from what ive read its air intrusion ? If you all think it is in your experience where would be the most likely culprit. It doesnt seem to matter which tank im pulling from. I dont see any leaky conditions around the fuel returns or injection pump. I dont know it is usually a hunt and punch kinda thing. any advice as always is greatly appreciated. thanks oh yeah its a 87 f-250 with a jasper 7.3 idi . c-6 auto 4x4.
Old Aug 3, 2010 | 11:24 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The return line tee's on each injector have two O rings under each of them.
When the engine is not running, they are leaking air in, which drains the fuel filter.
The fuel is returning to the fuel tank, so no fuel on the outside of the engine or under the truck.
If you pull the fuel filter before you start the engine, you will see it is not full in the morning.
Fill it up and the die and hard restart will not happen.
Old Aug 3, 2010 | 11:33 PM
Rick Wallace's Avatar
Rick Wallace
Check the lines at the water seperator,they are bad to rot at that spot
we287gn
21
Jan 2, 2018 07:48 PM
boots6868
Mar 8, 2017 09:46 PM
3000gtman
16
Feb 9, 2017 12:22 AM
mattnj
Nov 7, 2016 09:25 AM
Nibor
Dec 5, 2013 12:14 AM
