Battery Light in the Instrument Cluster is ON
Old 08-03-2010, 09:26 PM
SmokeBlower's Avatar
SmokeBlower
SmokeBlower is offline
The battery light came on today while I was working on/driving my 1994 F350.
I cleaned both terminals.
I removed the negative cable while the truck was running and it kept running without any problems or changes.
With the truck off the voltage on the battery is 12.44
With the truck on the voltage on the battery is 14.14
Truck starts without any problems. What is the battery light trying to tell me?
Old 08-03-2010, 09:31 PM
DreadyDiggs's Avatar
DreadyDiggs
DreadyDiggs is offline
Test voltage with the truck on again. Rev the engine up as you do so. Make sure it doesn't go any higher than 14 volts. 15 to 16 is getting to a not so good range.
It could also be that this has nothing to do with the battery/alternator voltage but a short in the cluster.
What were you working on when the light came on? Anything else happen?
Old 08-03-2010, 09:35 PM
SmokeBlower
I think it came on after I removed the negative cable from the battery for an hour. I was trying to reset the pcm. I have been checking vacuum lines, spark plug wires, and fuel components. I will go see if I moved some wires around on the alt, I already checked it but I will check it again.
Old 08-03-2010, 09:49 PM
DreadyDiggs
If the battery has correct voltage (engine off test), and alternator passes also (engine running test) then I'd ignore it and see what happens honestly.
Usually that light will indicate a charging failure, ie alternator not putting out correct voltage while the truck is running. If you're saying that's not happening, I'd ignore the light haha.
Uh, did you do anything else to the truck besides disconnect the negative cable?
Old 08-03-2010, 10:14 PM
SmokeBlower
I just went out and re-checked the voltages:
12.14 with the engine not running
13.33 with the engine running at idle
13.39 was the highest it got while holding the throttle half way open
I have to drive the truck tomorrow. I put an extra (good) battery, the voltmeter, and a set of jumper cables in the back seat. Just in case.
I am actually replacing the instrument panel this week, so we will see if it is the gauge cluster short or if the battery light stays on in the replacement.
Old 08-03-2010, 10:49 PM
DreadyDiggs
Battery light's on because the alternator is failing. Not the battery, but the alt.
13.3 is UNACCEPTABLE. Yank the alt and go get it tested, or try and test it yourself again later.
The alternator's still working at this point, but it should be putting out at least 14 constantly, you're not running on battery alone just yet, but you're on your way.
Old 08-03-2010, 10:57 PM
CJM8515's Avatar
CJM8515
CJM8515 is offline
Alt is bad, replace it.
Old 08-04-2010, 07:28 AM
SmokeBlower
I drove it 90 miles so far. The battery light was going off and on the whole time. I will have the voltage regulator checked on the back of the alt today.
Old 08-04-2010, 01:07 PM
DreadyDiggs
Good man. If can just get the entire alt checked, not just the regulator.
Old 08-04-2010, 06:15 PM
SmokeBlower
This afternoon the light never came on. It went 45 miles and at least 10 red lights, plus 1 stop to at the store. No battery light issues this afternoon so I did not go to the auto parts store.
Old 08-04-2010, 10:28 PM
DreadyDiggs
I guess whatever floats ya boat my man. Your tests say the alt is dying. If you're not gonna test it or just replace it, monitor it. However, even that will not prevent it from dying whenever and where ever it wants to.
Old 08-04-2010, 10:36 PM
nflfreak43's Avatar
nflfreak43
nflfreak43 is offline
yep. by it not charging fully not only is the alternator dying but its slowly killing the battery also. if you continue on like this you'll be replacing the alternator and battery.
Old 08-05-2010, 06:45 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Its def a bad alt. Altho, some parts stores will tell you it tests "good" it is not. I had a rebuilt lifetime warranty alt have low voltage after it was warmed up. The tested it with it on the pickup, told me "its good still" it was charging at 13.6 volts. Needless to say, if I had the lights on , and the blowEr motor on hi, it was discharging the battery. The next time I took it to the store to get it tested, I had all the lights on the A/C on, and it in reverse(with the parking brake set) and it failed. I got them to give me a higher amp alt for the warranty exchange.
Just replace your alternator. It will save a headache later on.
Old 08-05-2010, 07:49 AM
subford's Avatar
subford
subford is offline
Sounds like the belt may be slipping. Check your belt tension device.
Also NEVER removed the negative cable while the truck was running, this make electronic devices go bad as the voltage can spike over 100 Volts.
You never want to clear your codes by taking off a battery cable either as this can also cause problems and set a code. Clear codes with the STI wire, and when the MIL starts to flash take the ground away from the STI wire. The codes will be cleared.
Old 08-05-2010, 09:15 AM
lew52's Avatar
lew52
lew52 is offline
X 2 on the belt , to test the alt you need to test it with a vat-40 or simalar , needs to be under a load to tell the alt output....Lew
Quick Reply: Battery Light in the Instrument Cluster is ON
