Need help choosing new alternator
Old Aug 3, 2010 | 03:33 PM
gvsuman's Avatar
gvsuman
Hey everybody,
I have a 2001 v10 f250 crew lariat, and I need to buy a new alternator for it. I use a 9500# winch in the Fall times and I was thinking of getting a more "extra-duty" alternator to handle for charging power. Is there any better model than the other? Or is an alternator just an alternator? Thanks for your help!
Old Aug 3, 2010 | 09:38 PM
Franklin2's Avatar
Franklin2
You might want to consider a deep cycle battery to run your winch and any other accessories. If you have a place to put it, you can run a battery isolator and run your winch without even having the engine running.
Old Aug 7, 2010 | 03:40 PM
CABGx3's Avatar
CABGx3
Alternators are rated by their Amperage output.....60, 100, etc. The higher the number the greater the output of the Alternator, and the greater the cost. Of course the physical configurations vary, so you have to have the style that fits your vehicle, and the pully must match the rest of your system, or you can change it to one that does match.
Vaya con Dios,
Chuck, CABGx3
Smirks90
Nov 3, 2014 09:58 PM
robjef
Electrical Systems/Wiring
Oct 24, 2010 04:06 PM
satelliteman38
May 9, 2010 05:13 PM
lsjinkins
Feb 2, 2009 08:09 PM
56effiex
Aug 21, 2004 01:02 AM
