longest u've gone between oil changes?
Old Feb 13, 2003 | 03:31 PM
jjoel's Avatar
jjoel
so whose abused their car the most? who has gone the longes between oil changes?
Old Feb 13, 2003 | 03:47 PM
dougg's Avatar
dougg
My old Isuzu trooper had an oil leak used about a quart every 600 miles or so. I put 25K on it without an official oil change…
Had 230K onit when I gave it to my brother-inl-law and it still runs now.. Dam POS never dies,I tried!
Doug
Old Feb 13, 2003 | 04:10 PM
gamehunter's Avatar
gamehunter
Thumbs up longest u've gone between oil changes?
Wow, 1 qt every 600 miles. Thats like changing your oil 2500. You could go like that and never change the oil. I personally have probably gone 2500 at most. I usually change the oil when I feel its been a long time and I can't remember the last time I did. But then again, I don't drive around alot.
Old Feb 13, 2003 | 04:45 PM
pfogle's Avatar
pfogle
Forgetful and broke most of the time,... I have gone 6500 before changing.
Old Feb 13, 2003 | 04:56 PM
Border3899's Avatar
Border3899
I had a pan gasket go out in my truck and went through 5 quarts of oil a day, probably put on close to 7 or 8 thousand before replacing the pan gasket and changing the oil, i looked at it like i was getting an oil change every day, oil didnt have long enough to get dirty.
Old Feb 13, 2003 | 04:57 PM
Pastmaster's Avatar
Pastmaster
I've gone up to 3500 before on a trip. Believe it or not, when I changed it, the oil was in better shape than when I change it at about 2500 now.
Old Feb 13, 2003 | 06:00 PM
jjoel's Avatar
jjoel
well, i believe my dad is pushing 10,000 on our poor mini van. we frankly haven't had the money to change the oil so we're praying hehe.
my truck has ohhhhhh 2,500 miles (maybe a lil less) since its last oil change. so i'll probably change it myself or take it somewhere to change it (almost just as cheap to do it that way). anywayz.
Old Feb 13, 2003 | 06:08 PM
steve83's Avatar
steve83
If you don't have $10 for an oil change, you shouldn't be wasting a $4000 vehicle. Skip a trip to the movies or something and save the engine.
Old Feb 13, 2003 | 07:18 PM
oldblue18's Avatar
oldblue18
It's been about 18 months since I changed the oil in my f-150--it doesn't leak any, but I only drive it about 40-50 miles a month...
Old Feb 13, 2003 | 07:53 PM
Racerguy's Avatar
Racerguy
The record I've seen at the shop I work at is a 302 with 95,000 kms (approx 55,000 miles) with the original oil filter. At the factory the filter is painted gray with the engine so it's easy to tell if it's original. Change the oil? We don't need to change the oil...we have warranty!!!
And yes the oil didn't flow out of the drain hole very well
And no, he didn't get anything covered under warranty
Old Feb 13, 2003 | 09:16 PM
92lightning's Avatar
92lightning
I put about 800 miles on my truck a week. The oil gets changed 4 times a year. I check it once in a while it never has needed more than a half a guart. I repoed a Jimmy that had 1 1/2 guarts of oil in the motor. The driver had not chanced it in 30,000 miles. I put 10,000 miles on it after that.
Old Feb 14, 2003 | 12:26 AM
f150sleeper's Avatar
f150sleeper
When I was a parts runner I drove a 2000 gmc seirra. I used to beat that truck so bad youd be surprised the sounds that a tranny and rear end will make and still not break. I started driving the truck when it had 15000 miles on it and I drove it for about 10000 miles and never had the oil changed. It had some nasty piston slap in the morning by the time I got done using it. Nothing like beating on the company vehicle.
Old Feb 14, 2003 | 12:34 AM
mrwizard's Avatar
mrwizard
Remind me never to buy a used vehicle from some of you.
Old Feb 14, 2003 | 12:26 PM
92Pony's Avatar
92Pony
In 1987, my Dad bought a new Nissan pickup. At 15,000 miles, I bought oil and an oil filter and changed it for him. That truck ran to 210,000mi before the motor started knocking. Heck, it made it through three teenage boys learning to drive to boot!!
The longest I've ever let one of my cars/trucks go is probably 6-7000mi or so. I'm pretty **** about oil changes.
Wade
Old Feb 14, 2003 | 03:37 PM
thomasr's Avatar
thomasr
When I was a kid I worked for a farmer that had a 1968 GMC 1/2 ton pickup...had a 6 cyl in it. I think it already had a jillion miles on it when I started working for him. It never saw a lot of hard, hard useage, just a lot of running around on the farm, errands and such. But the thing burned about as much oil as it did gas. You could always tell where it was by the tell-tale cloud of blue smoke...it was incredible. The oil never got changed in it for the entire 3 years I worked there. In fact, we never added any "new" oil to it...the old guy I worked for insisted we use the old oil we drained form the other equipment. Now this farmer was religious about his preventive maintenance on all his other equipment...just not this old GMC...he could have cared less about that truck. Actually the clutch gave out before the motor did...pulled it over in the weeds and left it.
REX
