Rebuild How-To Question
Old Aug 3, 2010 | 11:42 AM
cowmilker08's Avatar
cowmilker08
I need to fix the outer u-joints and ball joints on my front end, so I think it would be smart to just rebuild the whole dam thing. Its a D50, and I don't have the funds to swap to the D60. So I am looking for write-ups, links, etc. to help me get this done as quickly and cheaply as possible.
Old Aug 3, 2010 | 11:58 AM
redman84's Avatar
redman84
Pull your front wheels, take off brakes and hang em up somewhere, and get some beer. Take your locking hub assembly out slowly and store it methodically. Pictures helped me here a ton. Pull the rotor. Then the spindle. Get extra beer for the spindle. If you've never pulled it then you're in for a treat. After that the D 50 shafts should pull right out. The passenger one has a rubber boot you can take the clamp off of and that shaft pulls right out too. You may as well do your bearings and races while it's apart. Soon I'll put up some pics of the hub disassembly. I don't know the rest. Good luck.
Old Aug 5, 2010 | 11:51 AM
cowmilker08
I've
had
the
hubs
apart
several
times.
I
have
also
had
the
spindles
off.
I
was
curious
about
changing
the
ball
joints,
center
pivot
bushing,
and
center
u-joint.
Any
info
on
that
stuff?
Sorry
for
the
wierd
post,
but
my
spacebar
isn't
working.
Old Aug 5, 2010 | 12:20 PM
Hussler's Avatar
Hussler
Where you want a space hold down the Alt key and key in 032.
I'm doing it now. Fortunately keyboards are cheap.
Old Aug 9, 2010 | 04:36 PM
cowmilker08
I'm using my father-in-law's computer now. I had to send in my laptop, hopefully get it back before school starts. Best Buy is on my **** list now too. That trick seems to be working.
So does anyone have info on the question at hand?
Old Aug 9, 2010 | 06:03 PM
Red97350's Avatar
Red97350
Safety First, always make sure vehicle is properly supported and wheels chocked. It is easier to change the ball joints while the front end is in the truck, but I did it while it was out and it wasn't too bad. You should start by getting a "C" frame press kit. You can get them at harbor freight or parts stores may rent them. I'd take the ball joints off the front end first and then take the front end out of the truck. I degreased the front end and repainted everything with POR15 before I put it back together. Just take everything apart carefully and take your time, it really isn't too bad. If you're going to do axle pivot bushings, I just posted a mini "how-to" on Travis' pivot bushing thread. If you really want to get into it, you can do leaf spring bushings to and even paint the chassis while you're down there. Hope this helps and be safe.
Red
v8xploder
1978 - 1996 Big Bronco
Mar 17, 2026 08:09 PM
stainlessstroker95
97
Feb 18, 2013 09:11 PM
Jayme Duty
Jul 19, 2011 07:55 PM
galute
Sep 29, 2010 10:11 PM
Ken2600
Mar 6, 2003 11:07 AM
