Speedometer does not work
Old Aug 3, 2010 | 09:06 AM
Alcaeus's Avatar
Alcaeus
Hello all. I have a 82 f100 with a 4 on the floor that came out of (i think) a 84-5 f150. Its the Tremec RTS tranny.
My speedometer doesnt work at all. I replaced the speedo cable as the tip had broken off and I replaced the plastic gear that goes on the end of the cable.
when I hook that up to a drill the speedometer shows speed fine. When I stick it into the tranny it doesnt show anything while I am moving... I put the truck up on jacks and in gear to see if the inner gear is moving and it is spinning in there.
I felt the inner plastic gear and it seems to have a dip in the middle. Is it supposed to?
Does anyone know where I can source a part like that? Ford says the dealership closest to me with one left is in Canada as the part is obsolete. They wont even ship it in. I have to call that dealer...
any ideas?
Thanks in advance!
Tranny tag
RTS BV AH 8
E6TR MA 2222
Old Aug 3, 2010 | 09:11 AM
Franklin2's Avatar
Franklin2
I know it's hard to see in there, but can you tell if the gear on the output shaft is lined up to the hole? I had a tranny once that did this, and I had to take it apart and press the gear on further so it would line up with the plastic one.
Old Aug 3, 2010 | 10:16 AM
Alcaeus's Avatar
Alcaeus
It seems to be lined up in there. I stuck my finger in and it contacted directly with the gear... I cant see much but it also looks like it is lined up.
Boy I love old trucks
Old Aug 3, 2010 | 10:25 AM
f100jim's Avatar
f100jim
The drive gear in the trans should not have a dip in the middle. Sounds like it is worn out.
Old Aug 3, 2010 | 11:08 AM
Alcaeus's Avatar
Alcaeus
well hell.
anyone know where to find one?
Old Aug 3, 2010 | 11:10 AM
Rogue_Wulff's Avatar
Rogue_Wulff
You be able to find that gear thru a drivetrain specialty shop. One that specializes in transmission rebuilding.
I'm not sure if places like NPD or Obsolete Ford would have these gears, but it's worth looking into.
Old Aug 3, 2010 | 12:29 PM
Alcaeus's Avatar
Alcaeus
well... I called ford again and this time they say they should have the gear...
Anyone know if I can take the tail off while the tranny is still in the truck or is it too much of a pain?
Old Aug 3, 2010 | 01:48 PM
Rogue_Wulff
I think the tailshaft housing can be removed while the trans is still mounted, but you will likely need to drop the rear crossmember.
While I'm not that familiar with this particular trans, most tailshaft housings can come off somewhat easily, but since the mount is usually hooked to it, the crossmember has to come out.
It will really depend on how the shifter is mounted. Older 3/4 speed transmissions didn't have anything but the mount and speedo cable hooked to the TS, I can't speak for this unit though......
Old Aug 3, 2010 | 02:02 PM
Alcaeus's Avatar
Alcaeus
The shifter is in the top of the tranny itself not in the tail housing and the only other thing stuck on it is the speedo cable so hopefully... It will be easy.
Thanks guys!
Here is a diag of the tranny so it doesnt look too hard after all.
Old Aug 4, 2010 | 11:56 AM
f100jim's Avatar
f100jim
Suggestion: While you have the tail housing off, put a new rear seal in it. They are dirt cheap and easy to install.
Old Aug 4, 2010 | 11:59 AM
Alcaeus's Avatar
Alcaeus
I just replaced that seal. a prior owner had torn it up somehow.
While I have you all here....
The metal gasket that sits between the bellhousing and the engine is hitting the pressure plate when I depress the clutch...
Any ideas? Do I really need it? Can I cut out the part that is hitting?
Old Aug 4, 2010 | 07:19 PM
Barkin 40s's Avatar
Barkin 40s
i dont see how it would be hitting the pressure plate, probably hitting the flywheel. so make shure the engine to tranny bolts are tight and not loose
88_F0RD
15
Dec 4, 2016 12:45 PM
Cougar54
Aug 13, 2014 11:57 PM
JacobRM
19
Jun 3, 2014 06:35 PM
Guhfluh
Aug 31, 2013 06:01 PM
limeyellowfellow
May 15, 2012 08:26 AM
