Sponsored by: Real Truck
feedback on superlift truspeed
Old Aug 2, 2010 | 08:04 PM
kx125str99's Avatar
kx125str99
I am looking into the superlift truspeed speed recalibrator. I have a 2000 F250 diesel on 38.5 tires. I have read about it but there really isnt any reviews on it so i was wondering if anyone here has used it or heard of it. Any advice would help out greatly. Thank you
Old Aug 2, 2010 | 08:57 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The Truspeed has to be wired in to work, that's why I went with the Superchips TirePaq, because it plugs into the computer port. Switching tire sizes does require you the plug it in and flip the key a half dozen times, but at least it's not hard wired into the computer and a permanent fixture in the cab, plus how often do you really change tire sizes. The Tirepaq has worked fine for me, I'd recommend it. From what I remember during all my research before I got the Tirepaq, the Truspeed doesn't have a good digital readout, meaning you twist a screw until the reading on the speedo matches the speed you work out in a tire calculator. I personally prefer scrolling through a menu, picking a tire size, flipping the key a few times, and unplugging the whole mess and not worrying about it.
Superchips 1846 Superchips TIREPAQ.
Edit: I think the Tirepaq will end up being cheaper too, based on a quick google search
Old Aug 2, 2010 | 09:10 PM
kx125str99's Avatar
kx125str99
right now i am using a predator diablo sport programmer and still wanna use it. how does it work if i am stil using it.
Old Aug 2, 2010 | 09:15 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
What size tires does it go up to?
Old Aug 2, 2010 | 09:17 PM
texastech_diesel
Token Redneck
The Tirepaq works through the ABS module somehow, and as a device it isn't capable of affecting engine tuning at all, so I assume they'd be compatible.
I can't be sure of exactly how the Truspeed works since I've never touched one, but here's the install intrustions, it tells you which wire to cut, so you can probably read into which signals will be altered. The truspeed alters input data, the Tirepaq changes how to comp reads the signals.
http://www.superlift.com/instructions/33001.pdf
Old Aug 2, 2010 | 09:22 PM
texastech_diesel
Token Redneck
Tirepaq goes to somewhere around 42" max, Truspeed maxes out somewhere around 44" in their install guide.
Old Aug 2, 2010 | 09:24 PM
High Intentions
Mod Specialist ;)
Cool thanks for the info....I will be looking into this.
Old Aug 3, 2010 | 01:42 AM
_Rick_'s Avatar
_Rick_
I installed a truspeed about two? years back with some help from FTE.
I find it to be a great little unit and I do recommend it since it has performed as advertised with no problems at all for me. It has two settings that can be stored for different tire sizes which has proven useful for me a couple of times since I installed it. A flick of the switch and it's set for my winter tires.
The only bits of help I can offer is take your time with the install and make sure the wire splices you perform are solid and sealed.
You can place/install the unit (as I did) semi permanently beside the fuse box,,, zap strapped to the horizontal steel brace running under the steering column. Of course you can place it anywhere you like. I just found that spot easy to access with the fuse box access cover off to adjust the speed settings while driving using my GPS as the speed reference.
Note for Calibrating Speedometer:
Don't let the instruction manual confuse you when you get to the calibration section. All you need to do is use a GPS as a reference for setting the truspeed.
BTW:
If you do go with a truspeed unit,,, be patient and shop around for a good deal. I ended up paying around $130.00 or $150.00 CAD (memory is fading on me) after a couple of weeks of shopping around.
Rick...
Old Aug 3, 2010 | 08:38 AM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
I have an SCT X3 tuner from 5 Star Tuning and run the TruSpeed to correct the speedometer as the tuner will not correct it. I set the TruSpeed with a GPS to be spot on at 75 mph. It corrects the shift points, and the readings on the overhead console. I installed the TruSpeed in late 2001.
Superlift TruSpeed ratio converter
The Merlin Speed Wizard is like the Truespeed.
Truck Enthusiast Products
http://www.fmdkinc.com/Speed%20Wiz/s...04-install.pdf
I don't know of you can stack another Tuner if you run the Superchips 1846 Superchips TIREPAQ. You can have performance tunes added to it, but they are not "custom tunes".
Old Aug 4, 2010 | 05:51 PM
kx125str99's Avatar
kx125str99
Ok so sticking with the truspeed I can still run my diablo right?
Old Aug 4, 2010 | 06:47 PM
texastech_diesel
Token Redneck
Everything I've read points to yes. The Truspeed seems a to be a lot more friendly with engine tuners since it doesn't actually flash anything into the computer
Old Aug 5, 2010 | 06:14 PM
kx125str99's Avatar
kx125str99
Alright thank you for all your help. Superlift truspeed it is!
lowmpgv10
Jul 28, 2016 11:21 AM
Reddhorse
Feb 22, 2014 04:10 AM
Aussie BrianB
Australia Chapter
41
Jul 27, 2013 09:53 PM
deyauger
Jan 9, 2011 12:55 AM
