rattle start?
Old Aug 2, 2010 | 04:05 PM
rockpile's Avatar
rockpile
rattle start?
my 86 f-250 rattles or something when it starts for a couple seconds. Someone said the ignition sticks. Anyone have any suggestions?
Old Aug 2, 2010 | 05:01 PM
WoodHeat's Avatar
WoodHeat
rockpile...that is a vague description. What kind of rattling? Is is coming from the engine compartment, under the truck, in the back? How severe is the shacking? Does it rock you in the seat when starting? Are there any sounds you hear that sound odd? The answers to those questions will help people provide more accurate assistance.
Old Aug 2, 2010 | 05:16 PM
rockpile's Avatar
rockpile
its definitely coming from the starter rattling kind of a grinding.
Old Aug 2, 2010 | 05:30 PM
WoodHeat's Avatar
WoodHeat
could be as simple as the starter needing to be replaced. Mine made some odd noises before I replaced it. However, check first to see that it is bolted all the way in. Maybe it got loose a bit and is 'grinding & knocking' the flywheel or something.
Old Aug 2, 2010 | 05:41 PM
rockpile's Avatar
rockpile
It has always done it at least since I bought it two years ago. I just replaced the clutch and the fly wheel has no damage and the starter is definitely bolted in tight. One guy said the ignition stays on to long. Could be worn out starter maybe?
Old Aug 2, 2010 | 05:49 PM
WoodHeat's Avatar
WoodHeat
That depends on what he meant by 'staying on too long'. Does it make the sound like when you try to start a car/truck again after its already running? If it does then I'd think there is something up with either the starter itself or the starter circuit since its supposed to cut power to the starter after you let go of the key. Does it keep going after the key springs back to 'run'?
Check out this thread too: starter-keeps-turning-with-key-off
Old Aug 3, 2010 | 01:21 AM
86sixbanger's Avatar
86sixbanger
is sounds like a sticky ignition switch. maybe a squirt of WD-40??? or maybe have to take apart and clean/fix/unsticky. I know that on a lot of 80/96 fords I've seen where the ignition works fine but it's so wore out that you don't even need a key to start it. wierd.
Old Aug 5, 2010 | 05:40 PM
rockpile's Avatar
rockpile
I didn't take care of it and the fly wheel is stripped. Just did the clutch a month ago.
Old Aug 6, 2010 | 12:52 PM
WoodHeat's Avatar
WoodHeat
Dang...that bites...well, at least now you know what to fix to make things work right.
Old Aug 6, 2010 | 04:45 PM
rockpile's Avatar
rockpile
pretty strait forward just a huge pain in the ***. flywheel is orderd. starting to dismantle.
