Another Spring question
Old Aug 2, 2010 | 10:04 AM
blackford4x4's Avatar
blackford4x4
Smile Another Spring question
If i went with the w code springs up front what would be the best fit for the rear I want to keep the same rake with the rear up higher Thanks!!!
Also if i went with the v/b Swap and 3.5 tapered blocks (with or with out the spring mod) in the rear will it keep the factory rake with the rear up higher thanks again
Old Aug 2, 2010 | 12:21 PM
Stewart_H's Avatar
Stewart_H
A few options are available.
If you tow, you might wanna consider B codes, stock block, and RAS.
Or, you can go with stock block and modified B's along with the W's. This version might be closer to level, as opposed to the stance you want, with the rear slightly higher.
You can also go with the 3.5" tapered block and modified B's. But this might give you more rake than you want.
You might wanna also try no block, modified B's, and the RAS. Dunno how you would sit, but you can try and and let us know!!
As for your second question, yes on both parts.
Stewart
Old Aug 3, 2010 | 09:40 AM
blackford4x4
thanks Stewaet
I think i am gonna go with the v/b already have ras installed and love it. The reason for the change other than been wanting to for awhile is the ft driver side Spring is broken and only suspended by one leaf will try to dig up picts and show
norvillebob
Apr 29, 2016 07:14 AM
shademt
Offroad & 4x4
Feb 16, 2014 06:40 PM
pin8246
30
Aug 2, 2012 08:25 PM
sandman3510
Apr 1, 2008 06:13 AM
Boss300
Jan 30, 2006 04:23 PM
