I just did the oil change in my 04 Excursion and without thinking put a full 15 qts in. The previous owner or garage wrote 145 qts right on the fan shroud but I was just blindly filling it (I had three 5qt bottles of 10-40 Mobil 1) until the last bottle was empty. I drove it around and decided to wait until the morning to check it. Well, it is above the max line now and I'm afraid to drive it without draining the extra out. Unfortunately, I have to and I won't be able to drain it until tonight. How much trouble could this cause?
What a pain this is going to be. I will be buying a drain valve for it today!
I wouldn't even bother draining any. If you go to any dealer for your oil change, they are going to do the exact same thing you did. Three 5 quart jugs. Only the more enlightened here on FTE know to only use 14 quarts.
Matter of fact, I'm in the exact same boat. Dealer put in 15, and I'm just leaving it until my next oil change.
I agree except for one thing. I want to know if my level is ever increasing from fuel dilutiion. If the level is over the full mark to begin with, it is hard to detect this.
Yep, we agree on all that. Question is, is it worth it to me to drain 1 quart to make it through one OCI? Not to me. I'm much more annoyed by the fact that they filled me with 15W/40. I can't wait to get that out of there.
If you want to use Mobile 1, look for "Mobile 1 Turbo Diesel" oil. It only comes in 5w40 I believe. It may be a little tricky to find, i know around my area it is.
Not only that but the next oil change will leave 3 to 4 qts. Of the bad mix in the engine. I would change the oil with the cheapest api rated oil, run it for abiut a 100 miles light loading and change it again. I may be a little **** but two oil changes may turn out to be the cheapest option.
