94 wont start
Old Aug 2, 2010 | 05:48 AM
n.o.yat's Avatar
n.o.yat
94 wont start
my son has a 94.5 powerstroke. he just started having trouble starting his truck. the batteries are up and when running charging. the fuel bowl is full. i dont think its a glow plug problem. if i shoot a little starting fluid in it , it starts. no engine light on. sometimes it starts with no problem at all. thanks in advance.
Old Aug 2, 2010 | 08:15 AM
Talyn's Avatar
Talyn
Starting fluid = really bad.
Old Aug 2, 2010 | 08:16 AM
Talyn's Avatar
Talyn
We could really use some more information though.
Does the Tach move when it wont start?
Does it randomly shut off?
Do you know the Fuel pressure at the schrader valve on the Fuel Bowl?
Is the HPOP full after it has sat for a while?
Oil level up to snuff? They wont start if too low on oil.
Old Aug 2, 2010 | 11:06 AM
84-250's Avatar
84-250
does your "wait to start" light still work when you turn the key on? if not your fuel heater could have blown fuse #20 or #22. dont recall which
Old Aug 2, 2010 | 11:10 AM
Talyn's Avatar
Talyn
He said it sometimes starts 84-250.
Sounds like low fuel pressure or low oil.
Could just be a dirty FPR screen or a bad filter.
Algae.
Old Aug 2, 2010 | 11:54 AM
RRranch's Avatar
RRranch
Throw the starter fluid away. Don't ever use that stuff with a glow plug system. I will bet some of them are trashed now. I'd pull them out and see. Test the wiring on the way into them too.
Old Aug 2, 2010 | 03:30 PM
n.o.yat's Avatar
n.o.yat
wont start
he said that it sometimes dies when he is running down the road. lets it sit then it recranks right back up. the starting fluid was just a way to tell it was a fuel problem.
Old Aug 2, 2010 | 03:31 PM
n.o.yat's Avatar
n.o.yat
if it was the fuel heater it would not start at all . am i right?
Old Aug 2, 2010 | 03:32 PM
n.o.yat's Avatar
n.o.yat
what is a fpr screen?
Old Aug 2, 2010 | 04:11 PM
427 fordman's Avatar
427 fordman
cps been changed?
screen is in the fuel bowl, about an inch down on the drivers side. U can use a qtip with the cotton end broke off to clean it out.
Old Aug 2, 2010 | 04:30 PM
drivembig's Avatar
drivembig
Probably a Cam Position Sensor........
Old Aug 2, 2010 | 06:05 PM
n.o.yat's Avatar
n.o.yat
changed cps about a month ago
Old Aug 2, 2010 | 06:37 PM
427 fordman
sometimes they don't last long. Do you have a spare to try?
Old Aug 2, 2010 | 06:56 PM
Action4478's Avatar
Action4478
You didn't say if it was warm or cold problem . if it starts & runs for a while .I would replace the IPR O Rings first .. Its a cheap test
Old Aug 2, 2010 | 07:00 PM
Action4478's Avatar
Action4478
Don't worry about that yet , Its in the Fuel bowl, causes rough idle ..
