AMSOIL
Old Dec 12, 2010 | 08:11 AM
  #31
Buck 1's Avatar
Buck 1
Just a question: Who offered the lifetime powertrain warranty if you follow their oil change and rotation schedule? I may be interested in that...........
Old Dec 12, 2010 | 09:23 AM
  #32
drh1175's Avatar
drh1175
Not sure where you get your info from that Amsoil is not API. Amsoil is incredible oil. I have used it for a few years now and use it in everything.As a preffered customer I can buy it straight from Amsoil for just about the same price as Mobil 1 at my local autoparts store. The #1 reasoni like it is it is flowable down to -38. Here in MN i Appreciate that in the winter. The bottom line on all oils is it needs to be clean. Dirty Amsoil is no better than dirty conventional oils. I would not trust even amsoil after 7500 miles without a oil anaylisis done. To each is own on which oil you have faith in.
AMSOIL 100% Synthetic 5W-30 Motor Oil (ASL) delivers extraordinary lubrication in all types of automotive gasoline engines. By combining the industry-premier synthetic technology with AMSOIL premium additives, AMSOIL ASL exceeds the higher performance demands of modern engines. It withstands the stress of higher horsepower, higher heat and complicated emission control systems. AMSOIL Synthetic 5W-30 Motor Oil is engineered to outperform competitive conventional and synthetic motor oils. It delivers long-lasting performance and protection.
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine.
Extends Drain Intervals
AMSOIL Synthetic 5W-30 Motor Oil can extend drain intervals far beyond those recommended for conventional oils. Its unique synthetic formulation and long-drain additive system are very stable, resisting oxidation and neutralizing acids. AMSOIL 5W-30 Motor Oil is designed to deliver the best possible engine protection, cleanliness and performance over extended drain intervals, reducing vehicle maintenance and waste oil disposal costs.
Maximizes Fuel Economy
AMSOIL Synthetic 5W-30 Motor Oil is designed to maximize energy efficiency for improved fuel economy. Unlike conventional oils, its uniform molecular structure helps it flow more freely and reduce friction between metal surfaces. Anti-friction additives are included to further improve energy efficiency.
Reduces Engine Wear
AMSOIL Synthetic 5W-30 Motor Oil provides outstanding anti-wear protection. It has excellent viscosity film strength to separate metal surfaces and robust anti-wear additives to further reduce wear in metal-to-metal contact regions for improved engine life.
Reduces Oil Consumption and Emissions
Volatility (burn-off) occurs when oil gets hot, causing high oil consumption and emissions. AMSOIL Synthetic 5W-30 Motor Oil has the lowest volatility rate of the oils tested, making it the best at controlling volatility-related oil consumption and emissions (see chart below).
Excels in Extreme Temperatures
AMSOIL Synthetic 5W-30 Motor Oil resists thermal (heat) breakdown better than conventional oils. It is heavily fortified with detergent and dispersant additives to prevent sludge deposits and keep engines clean. And unlike conventional oils, AMSOIL 5W-30 Motor Oil contains no wax. It stays fluid down to -58°F for improved cold temperature oil flow, reduced bearing wear and easier starting (see chart).
Less High-Temperature Evaporation With AMSOIL
Lower Cold-Temperature Flow Properties With AMSOIL
<CENTER>
APPLICATIONS
AMSOIL Synthetic 5W-30 Motor Oil is recommended for gasoline engines, diesel engines (API CF, ACEA B5) and other applications requiring any of the listed worldwide specifications:
  • API SM/CF, SL, SJ ...
  • ILSAC GF-4, 3 ...
  • ACEA A5/B5 A1/B1
  • JASO VTW
  • GM 4718M, 6094M
  • Ford WSS M2C929-A
  • Daimler Chrysler MS-6395N
  • VW 503.00
MIXING AMSOIL
AMSOIL Synthetic 5W-30 Motor Oil is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
Aftermarket oil additives are not recommended for use with AMSOIL motor oils.
SERVICE LIFE
AMSOIL Synthetic 5W-30 Motor Oil is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline fueled vehicles as follows:
• Normal Service(3) – Up to 25,000 miles or one year, whichever comes first.
• Severe Service(4) – Up to 15,000 miles or one year, whichever comes first.
• Replace AMSOIL Ea oil filter at the time of oil change up to 25,000 miles or one year, whichever comes first (other brands at standard OEM* intervals).
• In all non-gasoline fueled vehicle applications, extend the oil change interval according to oil analysis or follow the OEM* drain interval.
</CENTER>
Old Dec 12, 2010 | 11:11 AM
  #33
shotgunz's Avatar
shotgunz
As I stated above:
Originally Posted by shotgunz
Looks like some are and some aren't.
AMSOIL API Licensing
Old Dec 13, 2010 | 04:48 PM
  #34
LxMan1's Avatar
LxMan1
Amsoil has also been proven to get thicker over time. Not good for a Ford Modular engine.
Here is my 88 5.0 Mustang engine after 165K very hard miles. Never ran anything but Dino oil and a Motorcraft filter. Still holds 40psi oil pressure hot!!! Got a built engine cheap so I put it in. Many many miles left on this one!! No sludge at all!!!
Old Dec 14, 2010 | 06:27 AM
  #35
Diesel Man 03's Avatar
Diesel Man 03
Boys will be boys with their toys, use whatever you feel is doing the job you need.
deep6
Oil & Lubrication
63
Jul 22, 2014 05:50 PM
horsepuller
Oil & Lubrication
903
Dec 12, 2013 12:07 AM
redfire42
51
Aug 17, 2009 02:39 PM
