QUESTIONS ON IPR
Old Aug 1, 2010 | 02:02 PM
quality1construction's Avatar
QUESTIONS ON IPR
I have purchased an ipr rebuild kit, and all new fuel line o-rings. I reached down in where the ipr is located and you can turn the connector about 3/8 of an inch left and right, the tin nut is tight, relay does not move, just where the connector fastens to the relay, is this normal, or should I replace the whole relay.
Thanks much.
Old Aug 1, 2010 | 08:34 PM
F350-6's Avatar
F350-6
A little bit of slop rotating around the shaft is normal.
BlueScab
Jul 24, 2013 10:26 AM
FossenRacing
May 3, 2013 10:24 PM
jmpape
17
Jun 29, 2012 04:09 PM
King7765
Oct 29, 2011 05:22 PM
dirtworker
Apr 9, 2008 11:35 AM
