ipr pigtail
Old Mar 19, 2008 | 10:48 PM
dirtworker's Avatar
dirtworker
ipr pigtail
does anyone know where i can get one? ford says that they are unavailable, and i have to replace the whole harness. i'm hoping that someone knows of another application that uses the same connector that i could get. any help is appreciated
Old Mar 19, 2008 | 10:53 PM
rotun's Avatar
rotun
Reads ***** rules!
try TYCO, I was looking for connectors and stuff as well, found out the majority of Ford connectors are made by them but beware...will take hours of searching to find the right one.
Old Mar 20, 2008 | 06:51 AM
BowTieHatr's Avatar
BowTieHatr
the vgt connector is pretty much the same on the old style but if you get the connector from ford, it will have plastic ears instead of the metal lever which will make unplugging the ipr a nightmare
Old Mar 20, 2008 | 07:18 PM
dirtworker's Avatar
dirtworker
ok thanks guys
Old Apr 8, 2008 | 07:22 PM
dirtworker's Avatar
dirtworker
i was at my dad's shop today and glanced over at a set of 7.3 valve cover gaskets and noticed that the connectors that plug into the 7.3 injectors are the same as the 6.0 ipr and vgt. i cut one off and transplanted it and it works perfect, they even have the wire safety latch. just thought i'd pass the info along because these are available from ford and even though you have to buy the entire gasket harness for one side its still cheaper than a 6.0 engine harness.
Old Apr 8, 2008 | 08:47 PM
brickie's Avatar
brickie
Thanks dirtworker.I have a modified dodge part as my IPR pigtail because ford couldn't find the pigtail.
Old Apr 8, 2008 | 09:48 PM
dirtworker's Avatar
dirtworker
you could probably get the 7.3 harnesses from ebay pretty cheap
Old Apr 9, 2008 | 11:35 AM
BowTieHatr's Avatar
BowTieHatr
sorry i didnt think about this sooner. the lcf trucks had a recall for a ipr heat shield that also included an ipr connector. part number is 6E7Z-14S411-A for the pigtail.
Jzinkiewicz
32
May 2, 2021 12:57 PM
mtntop1
Feb 9, 2017 08:44 PM
Leatherneck007
Jun 26, 2014 05:43 AM
RIKIL
Colorado Chapter
142
Mar 20, 2013 07:49 PM
67bullitt
Nov 3, 2003 01:41 PM
