Timing Cover Seal leaking...
Old Aug 5, 2010 | 10:53 AM
timbersteel's Avatar
timbersteel
UPDATE:
Got it all back together. No leaks! (YET) I had to cut the *U* gasket on the oil pan, but couldn't cut the gasket on the sides of the pan(they had a metal structure). Anyway, RTV'ed the housing and the sides of the oil pan where I had tried to cut the passenger side and realized it wouldn't cut through, and bolted it all together. That was really easy, even though I thought I didn't have the harmonic balancer far enough on, but re-did it and everything was good.
Thanks to everyone that chipped in on help and ideas.
Old Nov 13, 2010 | 11:26 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by 86F150302
Its not hard but its a PITA!
Use plenty of RTV on the oil pan gasket to timing cover gasket..
harmonic balancer puller will be needed and a good gasket scraper.. Other than that normal tools.
Here is when I did mine.
My trucks present to me.. - The National Lightning Owners Club Inc
Nice write up. I'll be doing the timing cover tomorrow. How did you get the harmonic balancer back on? Shall I just use the center bolt and impact gun to suck it back on?
Old Nov 14, 2010 | 11:00 PM
86F150302's Avatar
86F150302
Thank you. Thanks for the rep point also. 1 back at you.
Balancer goes back on just by tightening the bolt back up. I just used a breaker bar. I have no air tools
I think the torque specs are 70-90 pounds.
TheDudeAbides
Mar 7, 2017 05:28 PM
Stewart_H
Oct 18, 2016 07:12 PM
carguy3j
Aug 2, 2016 04:34 PM
StanleyZ
Mar 26, 2015 03:01 PM
bigb609
Nov 21, 2011 05:35 AM
