Sea Foam Fuel Additive
I was thinking of adding Sea Foam fuel additive in my fuel. What do you guys think of this??
Also, I read on the Sea Foam home page that they recommend removing the fuel filter and filling the fuel bowl with Sea Foam and replacing the filter and starting your engine for 5 minutes or so.
I don't know how to add a link to their web page or I would.
2002 f-350, 7.3 P/S
2002 f-350, 7.3 P/S
I dont sell that to my customers for a fuel additive. I could of sold a crap ton of it and help the company out with numbers. But Im not into selling parts and fuel additives to harm someone elses vehicals so I can get a few dollars rollin in the door. Don't use it in the diesels. Your injectors are expensive. Use only the white or gray bottles of Power Service in your truck. You'll be alright with those.
Still dont trust it. Just change your oil every 3 to 5k. Use Rotella.. There is enough additives in there to do the job. Use a premium filter too. The better micron filtration the better. Moble 1 has a 99.8% micron filtration. Others use the Motorcraft FL-1995 filter, and other various brands.
I dont know why you want to run a fuel conditioner in your truck, if its having problems or you want to prevent problems. Im not trying to sell this stuff to you, just trying to help out from my experience. I have seen this stuff work wonders in diesel engines that had poor cylinder balance. Probably has saved me from replacing at least 3 sets of injectors this year. Its kind of expensive, I think a gallon is like $55 but if you are just running it in the maintenance dilution it treats over 1200 gallons, so not so bad if you look at it that way. Hope this link works.
https://jdparts.deere.com/partsmkt/d...lInjectors.htm
Seems like I saw a report on the top fuel additavies for Diesels and I was somewhat suprised that Seafoam wasn't even on the test. I have run it in my gas engines and I run AMSOIL fuel treatement and cetain boost in my diesels. It does say on the side of the can and on their web site that it's safe for diesel engines.
Some folks suggest putting Seafoam into your crankcase and then running the engine for a few minutes and then doing an oil change. I'm a little leary about doing that though.
As I recall AMSOIL ranked in the top 5 in the particular test that I saw but good ol' B5 petrolium diesed/biodiesel blend was the best fuel addative on the test. I'm fairly sure that they used commercially manufactured biodiesel and not homemade stuff from your other brother Darrel.
TinyWonder
TinyWonder
I know people who are big fans of Seafoam, but it is more gadget per my experience.
Just like WD40 can be used on everything -good on nothing.
I used it to clean intake deposits on my diesel Mercedes and it did absolutely nothing.
Than years ago I had good results cleaning diesel system on 20 years old Mercedes by using Moly diesel purge. That stuff can be bought on ebay or at local automotive story. For some reason the big chains are not selling it.
To the OP - I found 1.5 MGP increase in the last three tanks after adding Seafoam to my FUEL system. I went from 15.5 mpg to 17, which oddly enough is what I used to get 30k mi ago... At 160k miles on my injectors, the thought that maybe there were some deposits on the fuel side seemed more than reasonable.
I would not hestitate to add it again. I added a can at about 1/4 tank and put 100 miles on it.
I would be leery of adding anyting to the oil side....
After a quick search I located the comparison of addatives that I mentioned in my first post.
Here's the link...
Lubricity Additive Study Results - Diesel Place
Here's another from our own website.
https://www.ford-trucks.com/article/..._Results_.html
Take the information with a grain of salt. In other words use your own judgement and caution. The usual legal disclaimer applies. I don't have a dog in this fight and don't sell any of the products listed. Use of some of these products have been know to cause erectile disfunction, etc. If an erection last more than 36 hours... you get the point.
TinyWonder
Here's the link...
TinyWonder
