Riff Raff RFx?
Old Aug 1, 2010 | 09:23 AM
theSLEEPER's Avatar
theSLEEPER
Riff Raff RFx?
Anyone run one? I just have a few questions.
Old Aug 1, 2010 | 09:37 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I've got one and love it!
Old Aug 1, 2010 | 09:48 AM
theSLEEPER's Avatar
theSLEEPER
Really? I'm just wondering how the block works? It looks like it's tapped and the fuel is running through it, I guess I'd have to see it in person. Did you notice any gains?
Old Aug 1, 2010 | 04:58 PM
Stewart_H's Avatar
Stewart_H
Lotta guys are heading back from Tennessee from the 2nd Annual RiffRaff East GTG, so you might have to wait for more posts.
Stewart
Old Aug 1, 2010 | 05:34 PM
Duzitall's Avatar
Duzitall
It's a machined block that bolts in place of the stock fuel regulator cap. The regulator still works the same. The new block and hoses let a very small amount of fuel out of each head and return it to the return fuel line after the pressure regulator. Since the return orifice is small, it doesn't need to have a regulator or be before the regulator.
It's a nice piece and a very clever idea on how to return our engines to the original design by International that was altered by Ford bean counters. I have one sitting on my workbench to be installed ASAP. Unfortunately, my entertainment is not a priority for my work or my family.
The "gain" you will have is knowing that air can finally pass thru and out of the fuel rails in each head without passing thru your injectors.
Hope that helps your questions.
Old Aug 1, 2010 | 05:52 PM
WA.Ranger's Avatar
WA.Ranger
Exactly what he said^^^^^^^^^^^^
Old Aug 1, 2010 | 09:38 PM
theSLEEPER's Avatar
theSLEEPER
Right. I guess the biggest question I have is, how big is the orifice?
Old Aug 1, 2010 | 09:46 PM
Duzitall's Avatar
Duzitall
Can't see it. It's inside the housing. You can blow just a little air thru the hoses. Small. I would guess Clay used the same size hole as the old (non-dead-head) PSD's had.
This mod was also done years ago by some of the guys on the old forddiesel.com site now known as thedieselstop.com. Clay simply has put it into an eloquent kit form.
Buy it.
Old Aug 1, 2010 | 10:36 PM
big poppa's Avatar
big poppa
The FRx really seemed to quieted up things under the hood, noticably quiet. I'm not hearing that no# 8 injector knock I used to hear and just smoother idle and exceleration, really a worthwhile mod. Clay hit a homerun with this setup. One thing to consider, use some somewhat thick wire loom or heat or fire resistant wire loom on your hoses, I used some thin wire loom and one of my hoses rubbed a oil line from the vibrations and was scrubing the loom and went thru starting to scrub the FRx hose, so just do it as a precaution, loom is fairly cheap insurance.. Another thing too I need is a fuel pressure gauge, thats coming next when finances allow. If you can swing it, get that too, very good to have.
Old Aug 2, 2010 | 09:12 AM
theSLEEPER's Avatar
theSLEEPER
One more question. Is DFA gone? Or what?
Old Aug 2, 2010 | 01:14 PM
theSLEEPER's Avatar
theSLEEPER
Just to be clear, I love the RRD piece. It looks nice, but I'd like to have the option to upgrade.
Old Aug 2, 2010 | 02:55 PM
Kwikkordead's Avatar
Kwikkordead
That is a perfect description of what the crossover does.
And I get to brag that is was my idea!
Clay and I talked about the design of it before he brought it to market.
Here is the picture of the very first prototype design that is still installed on my truck 5 years later.
Old Aug 2, 2010 | 03:10 PM
USAF CCM's Avatar
USAF CCM
Dan,
If we ever get to Seattle to visit my wife's brother & family.....I'm going to make it a point to visit your shop just to meet you and shake your hand! I look at every response you provide because they're ALWAYS valuable! God Bless! V/r Les
Old Aug 2, 2010 | 05:02 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by USAF CCM
Dan,
x2.
Stewart
Old Aug 2, 2010 | 06:10 PM
theSLEEPER's Avatar
theSLEEPER
Nice! Is that the reg? Or the cross? I'm guessing there's an orifice right there before that 90*? Where did you get those fittings?
