fuel injectors?
number 5 and 6 cyl seem to be dead they both have 125 compression,spark from the coil pack and @ the new plugs,I checked the injector plugs and seem they were snapped in place.while running if you remove either plug wire #5 or 6 theres no change in motor tone ( I know this is a primitive test however im an old out board mechanic and we used to use this method lots for diagnostic purposes) if you pull of plug # 4 the motor stalls so looks like thats the only one working on that bank. could it be 2 bad injectors side by side any advice is appreciated ..
<!-- / message --> <!-- controls -->
