Check Ford-Truks first
Old Aug 1, 2010 | 04:38 AM
cymraeg's Avatar
cymraeg
Hi All
My '98 Explorer produced a nice set of error codes last week, before limping home.
<O</O
<O</O
P1747 Electronic pressure control solenoid – short circuit<O</O
P0135 Oxygen Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)<O</O
P0155 Oxygen Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)<O</O
P1409 Electronic Vacuum Regulator Control Circuit Malf.<O</O
P0743 Torque Converter Clutch Circuit Electrical<O</O
P0750 Shift Solenoid A Malfunction <O</O
P0755 Shift Solenoid B Malfunction <O</O
P0760 Shift Solenoid C Malfunction <O</O
P0765 Shift Solenoid D Malfunction
The first garage that I went to, told me that they would have to strip my gear box, so I went home and did some research on here. The opinion was it had to be an electrical fault as all of the above is on the same circuit.
I then went to another garage with my research they checked the wiring and found a dirty connector. All sorted and it only cost me 2 hours labour.
Thanks
Simon
Old Aug 1, 2010 | 07:38 AM
ncranchero's Avatar
ncranchero
A little homework goes a long way. Congratulations!!
Old Aug 1, 2010 | 11:23 PM
Moto Mel's Avatar
Moto Mel
Welcme to FTE. Glad that you used the search function and that it helped you.
The first shop you went to must have been "Bend Over Motors" every town has several of them. You were fortunate to have found an honest shop for the problem.
Beaglebus
Feb 17, 2015 09:42 AM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
PA F250
17
Aug 28, 2013 06:35 AM
jeepfix
Jul 24, 2013 05:56 PM
F350Stew
Aug 20, 2012 08:40 AM
