58 Panel truck
Old Jul 31, 2010 | 09:47 PM
anderson sc's Avatar
anderson sc
58 Panel truck
Just got a new project 58 Panel truck! This will take some work. Seller is bringing me a 78 LTD frame. He said it had a 58 truck on it and had planned to use it on the panel truck. What do you think? Or just up grade front end. Is this a 9" rear end in picture you will also see another member under front end because it had a chevy motor in it. Will be back to Ford power. Do want power steering and power brakes. Going to try to add pictures if I can't get it to send look at my album. Thanks
Old Jul 31, 2010 | 09:48 PM
anderson sc
Oh Paid $600.00
Old Jul 31, 2010 | 09:50 PM
anderson sc
Old Jul 31, 2010 | 09:58 PM
anderson sc
Old Jul 31, 2010 | 09:59 PM
anderson sc
Old Jul 31, 2010 | 10:58 PM
3rdshiftDiscretion's Avatar
3rdshiftDiscretion
plans for it?
Old Jul 31, 2010 | 11:24 PM
arctic y block's Avatar
arctic y block
It would make a cool 4X4
Old Aug 1, 2010 | 08:18 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by anderson sc
Interesting helper springs, I have never seen that type! Looks like a good project!
Old Aug 1, 2010 | 10:24 AM
52 Merc's Avatar
52 Merc
That is a 9" rear under your truck. So that's a good start. I wouldn't throw all that away to put a car frame under it. They don't have near the strength and rigidity as your truck frame. They're actually quite floppy if you've ever seen one with the body off. They get as much as give strength in combination with the car's body.
You can upgrade your truck brakes easy enough, and power steering can be added to your existing front end, or you could convert it to some type of IFS, if desired. That's my 2c.
Old Aug 1, 2010 | 11:16 AM
anderson sc
I didnt see the springs myself untill I post the picture wonder if they really worked?
Old Aug 1, 2010 | 11:22 AM
anderson sc
Thanks for your info! Will get frame later this week I'll send Pictures.
black58
Feb 18, 2012 08:58 PM
truckdog62563
May 15, 2009 06:00 AM
john/hlptruck
31
Feb 14, 2009 10:13 AM
DAFBFD58
Delaware Chapter
26
Apr 23, 2008 03:40 PM
