4.9L 300
Old Jul 31, 2010 | 08:18 PM
smash61's Avatar
smash61
4.9L 300
Hey im new to this site, i heard about it from one of my friends. i hav a 1994 f-150 4.9L 300 4x4 5spd WITH 150,000miles onit. the only problem i have with her is when climbing the mountains i'll go from 70mph to 45mph before i'm half way up it. that with down shifting into 4th so it doen't slow down any slower. but it does great through mud and pulling thing on flat ground. so what should i do? I should probably add some Hp but i wouldn't mind getting a little more torque as well so if you could point me in the right directions or any ideals. thanks
Old Jul 31, 2010 | 11:08 PM
Harte3's Avatar
Harte3
If you are downshifting to 4th than you must have a 5 speed OD tranny...don't think it was designed to climb mountains with it in 5th/OD.
Having said that, there are innumerable postings on this Forum asking the same thing you are about gaining HP and TQ. Grab some snacks and drinks, sit back and start reading.
Old Jul 31, 2010 | 11:19 PM
hgb4x4's Avatar
hgb4x4
what he said lol tons of info here ya just got look for it and read
Old Aug 1, 2010 | 01:49 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Also, tell us which gear ratio you have in the diffs, and what tire size you're running.
If you have 3.08 gears and trying to run oversize tires, you'll never get it to pull big hills with any speed.
Old Aug 1, 2010 | 10:59 AM
Harte3's Avatar
Harte3
Tall gears, OD transmission and big tires...it will die when it sees any kind of a hill.
Old Aug 1, 2010 | 03:03 PM
Rogue_Wulff
True. Even without an OD transmission, tall gears and big tires don't work well together.....
Old Aug 2, 2010 | 01:53 AM
jem44357's Avatar
jem44357
Sounds like you need to ds one more gear. My stock 93 4.9 5 speed with a bit bigger tires than stack will lug up some pretty tall hills if shes empty so long as the are short duration. Any distance and I need to ds to 4th.
Jim
Old Aug 2, 2010 | 02:54 PM
smash61's Avatar
smash61
thanks for help what should i do for a cam and and stuff for more TQ so i can get through more mud? i'm about to bore out .040 over for HP. already fut a k&n air fliter in it so she can breath and i going to buy som headers what else do you think i can do?
Old Aug 2, 2010 | 09:35 PM
JohnMcD348's Avatar
JohnMcD348
The typical answer I have been given many times before on this and other sites is that for a cam a decent unit is made by Isky. It's computer compatible and you would need that for the engine you have in there now. Since you're planning on boring it over, you'll have to really check to see if you'd get the best benefit from a mild or heavier cam. That I cannot answer. Being it is an EFI, I've been told by many also that the stock exhaust is pretty good header wise already. the stock EFI exhaust manifold is a big mod that the carbed guys do for cheap instead of spending the money on expensive headers. I'm not a big performance guy, just relaying the info I've been given enough by more than one source to feel it's worthy. Hope it helps. Also, check out FORDSIX.COM. Lots of people there that really want the most out of their engines.
Old Oct 1, 2013 | 07:07 PM
hoytaray's Avatar
hoytaray
fordsix.com. thanks I will check that out my self.
LA5054
Jun 4, 2015 08:35 AM
bigyellerdawg1991
13
Mar 12, 2015 10:58 AM
BIGRED-Fordzilla
Oct 8, 2014 11:23 PM
RA122524
13
Jul 10, 2014 01:33 PM
F100XL300I6
New Member Introductions
Apr 26, 2014 07:53 AM
