429 timing set for 460?
Cloyes 9-1122 Cloyes Street True Roller Timing Chain Sets
would this be good? what are the performance differences between double roller and the stock type?
Yes you got the right one, this simple mod is worth about 20 horses give or take. Make sure you get the double roller, crappy non roller sets wear out too fast and I've had a tooth skip before on one of my big blocks due to a worn out stock chain, and it's not like a Cloyes double roller costs a lot of money anyhow. 429s and 460s are nearly identical in every way except for the rod length and the crankshaft stroke. The 72 and up 385 series are the smog motors so make sure you order fuel pumps and timing chains for a 71 or older car engine.
You have any more questions about a 460 or 429 join up over at 460ford.com they are the base of knowledge for these engines and will not steer you wrong.
ok so on the cloyes double roller the "straight up" marks really are o* or 8* retarded? cause the cloyes sais from 1970-79and ive also heard that efi 460s have stock double roller straight up chains that would fit my 460, is this true
The one you have in the link is the exact same one that I have on my truck at the moment, and it will have 3 keyways like you see on the crank gear. The top dead center slot is 0 degrees (straight up) with the other two being 4 degrees advanced and 4 degrees retarded, it will specify which marking is which on the piece of paper that comes in the box. I believe EFI 460s are straight up from the factory but I cannot remember off the top of my head, sorry.
To be safe, make sure you get the one you had in the link that is for a 68-71. I ordered mine from Autozone about 3 years ago for about $35 I believe and they paid for the shipping. I ordered it for a 1970 Torino with a 429 if I'm not mistaken.
ok thanks you seem really knowlegeable could you look at my thread "msd mechnical advance" and see what you think? i made a account at 460ford.com but it hasent been activated yet.
thanks,
Brad
thanks,
Brad
taylorbickett5
Ford Truck Parts for Sale
May 13, 2015 05:04 PM
mdh1701
15
Nov 15, 2014 05:04 PM
rustygold1
61
Jul 28, 2013 02:56 PM
merc460
Jun 14, 2002 09:42 PM
