Timbrens with RAS
When you say 'squat'...how much exactly?
I have an 1100# tongue weight and use the RAS...I get about 1.5" of 'squat' in the rear of my Ex when hitched up with the WD engaged. I feel that is more than acceptable.
We have springs in the rear of our Ex and using them is not unacceptable in my opinion.
Have you ever seen a 3/4 or 1 ton truck when hitched up to a 5th wheel...they get some squat...so 'some' squat is acceptable IMO...please define your 'squat' level.
Thanks,
Joe.
Couple of observations.
First...if you mean that when you are hitched the front is HIGHER than when unhitched...you are not set right on the WD.
I believe if you have the Equal-i-zer BRAND hitch you can tilt the hitch head and get more WD transfer to get the front back down where it should be.
It is critical that you shift the front axle weight BACK thru WD FIRST. Using Timbrens, air bags or any other method in the rear to level the rear when you aren't transfering weight back to the front...is not the right approach.
First thing to do is get a tape measure out and measure the FRONT UNHITCHED height and then hitch up and adjust the WD until the FRONT HITCHED height MATCHES the UNHITCHED height...THEN you can make an assessment of needing more spring.
My guess...your WD bars may not be rated for the tongue weight of your trailer.
Also I believe that your tongue weight is much higher than you are estimating.
When I first weighed my camper it scaled out at just over 9000#'s...BUT the tongue weight was 1400#'s!!!...moving cargo out from under the front bed to the dinette benches got me to my 1100#'s of tongue weight...
So...my advice...get your WD set first and then we can attack the sag.
Also...a trip to the scale is the ONLY way to know for sure if you have your WD set right.
Finally...are you sure you have your RAS pre-tensioned correctly?
Good luck,
Joe.
